-   -   Solution for plastic broken/worn window crank guides (http://forums.pelicanparts.com/porsche-911-technical-forum/931593-solution-plastic-broken-worn-window-crank-guides.html)
ddinham 10-08-2016 03:54 PM
Re-installing the door glass in my 68-912. Could not get the window to stay in the window crank due to worn plastic grommets. Is there a solution for this or do I just replace the crank assembly?
http://forums.pelicanparts.com/uploa...1475967231.jpg
RSBob 10-08-2016 05:59 PM
If you don't get an answer here go to the Early 911S Registry for answers on all things early 911 and 912.
ddinham 10-08-2016 06:05 PM
Thanks Bob.
I did email Jim at EASY and am waiting for a reply.
Dana
