rnln's Avatar
Question: my 4 post lift makes groan noise
My Direct Lift DP-7000 groan like this: https://www.youtube.com/watch?v=nSXamm6DDVg
When going up with my car on it, it groans loud after about 1/3 of the way. It gets worse around mid way. On going down, it does less. Without a car on it, it's smooth and quiet.
It seem like the hydraulic cylinder is the issue. I inspected cable and wheels (roller disks) looks fine. I spray them with silicone lube, no help. Does anyone has this problem?
On hydraulic oil, I replaced several years ago (drained at the cable and filled at the oil tank). I don't think I use the lift that much that I have to replace oil too often.
Anyone know if I have to oil the hydraulic cylinder?
Fat butt 911, 1987
Old 10-09-2016, 12:56 AM
You need to add some hydraulic oil conditioner. It comes in a very small bottle and I think it is made by Cat. I had the same problem until I added the conditioner.
Old 10-09-2016, 01:37 AM
RETIRED
Joe Bob's Avatar
^^^^ this
2012 ML350 3.0 Turbo Diesel
Old 10-09-2016, 02:45 AM
rnln's Avatar
Investigator759, Joe bob,
I went to autozone website and typed "hydraulic oil conditioner" and found nothing. Do you remember what you get? If you have link to picture would be great. Thanks.
Fat butt 911, 1987
Old 10-09-2016, 03:03 AM
DanielDudley's Avatar
https://parts.cat.com/en/catcorp/1U-9891
It lubes the seals.
Old 10-09-2016, 03:44 AM
RETIRED
Joe Bob's Avatar
I got the conditioner from the company that sold me the lift and did the installation. Try them. They should be able to supply it (Free for me) or have a source for it.
Old 10-09-2016, 04:09 AM
rnln's Avatar
Wow, there is a place local, but far.
Thanks guys. How much should I put into the oil tank now?
Fat butt 911, 1987
Old 10-09-2016, 04:39 AM
Autodidactic user
David E. Clark's Avatar
Also, make sure that you know where all of the grease fittings are and grease at least once a year. Mine started howling several years ago. It drove me crazy for about three weeks until I discovered two grease fittings I didn't know about. Stupid, I know, but better that I discovered the hidden grease fittings before I did permanent damage.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 10-09-2016, 05:43 AM
Platinum Member
dad911's Avatar
Do the pulleys that the cables go over have grease fittings?
Old 10-09-2016, 06:12 AM
Autodidactic user
Mine do. The rear pulley grease fittings are covered by a large hex screw, about the size of a quarter. They look like part of the structure, not grease fitting covers. Those are the one's I "discovered". After I greased them, my problem went away.
Old 10-09-2016, 06:26 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Geez Rnln, 5:39AM, WTD, Get some sleep dude
Would help if you posted your lift's actual "groan" the joke video is funny but really does not help.
'85 Carrera Targa
PCA/POC
Old 10-09-2016, 09:46 AM
rnln's Avatar
Can you tell me where are your grease fitting are at? Which part? I looked at every corner of my lift and never seen one
Fat butt 911, 1987
Old 10-09-2016, 10:10 PM
rnln's Avatar
Really? I took more then one pulleys out on my hands before and didn't see the grease fitting. Is it on the pulley/wheel or on the part of the lift?
Fat butt 911, 1987
Old 10-09-2016, 10:13 PM
rnln's Avatar
It groan just like the guy did on the video, serious.
Search all over youtube and found nothing about lift groan nor grease
Fat butt 911, 1987
Old 10-09-2016, 10:14 PM
rnln's Avatar
Can anyone remember what she says? I can't concentrate
https://www.youtube.com/watch?v=g91tnGDIqTo
https://www.youtube.com/watch?v=MER5zkEC0wY
Fat butt 911, 1987
Old 10-09-2016, 11:33 PM
Autodidactic user
According to the Direct Lift Owners manual, you are supposed to "Lubricate the cable sheave shaft by using grease gun at lease once a year after the lift is in service." That tells me that there must be a grease fitting in the sheave shafts at the center of the pulleys. There may not be a grease fitting attached so it might simply look like a small hole to you. Screw in grease (Zerk) fittings and grease up each pulley until a small amount of grease oozes out of the shaft.
Here is a picture comparing your Direct lift (bottom) to a Bendpack lift (Top) from the Bendpak website. Apparently your lift did not come with grease fittings already installed.
Last edited by David E. Clark; 10-10-2016 at 08:09 AM.. Reason: Add picture from Bendpak website
Old 10-10-2016, 07:50 AM
rnln's Avatar
thanks David, I will check. Even without grease fitting, I can take the pulley off and put grease there.
Another thought, should I put grease on the pulleys where the cables run?
Fat butt 911, 1987
Old 10-10-2016, 08:09 AM
Autodidactic user
Make sure you look at the picture I added to my answer. It shows exactly where the grease fittings go.
As far as greasing where the cables run, I'd follow whatever the owner's manual recommends. I've never put grease on the pulley tracks on my lift and haven't had any problems. Plus, that grease will inevitably get on the cables and, if you park another car under the lift, that's just another way to get grease on your clothes when you get into your daily driver!
Old 10-10-2016, 08:22 AM
rnln's Avatar
David, thanks again. I will check tonight.
Fat butt 911, 1987
Old 10-10-2016, 08:46 AM
rnln's Avatar
Greased all pulleys' sharps and where cable run through the pulley too, still groaned. Left it for a week or so. 90% of the groan was gone. My buddy was here today and thought what left was the cylinder's seal. Gotta find that oil additive
Thanks guys.
Fat butt 911, 1987
Old 10-23-2016, 03:14 AM
