Turn signal don't work..... check this fix
I have a 1987 911, OK so a couple years ago I had my gas tank removed and they broke the fuse box... They JB welded it... everything worked. All of a sudden no turn signals, the turn signals all stayed light at the same time, hazards worked. So with 3 days off I founded the problem it was the middle section of the fuse box. I swapped that out and now they works great. so check for cracks. still cant figure it out but it worked.
Thanks for sharing Chris. If you documented your DIY step-by-step or are going to be doing more DIYs, you may be interested in the below link. If we publish your article, you'll be able to get 10% off your next order.
Enthusiast Tech Article Submissions - Pelican Parts -Dmitry |
| All times are GMT -8. The time now is 03:29 PM. |
