porsher
aston@ultrasw.c's Avatar
Quick release deck lid
My race car has a fiberglass deck lid with hinges and pins - no latch.
Now I would like to remove the hinges and replace them with pins.
However, *not* through the deck lid type pins that you see at the rear.
I was wondering about fabricating pins/mounts that would engage in holes in the opening at the top edge close to the rear window.
So, to remove: release rear pins and lift deck lid off.
To install: engage pins at the front, lower decklid over rear pins and install clips.
Has anyone else done this???
Can you post pics?
What is the hidden structure like along the top edge of the opening??
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 10-14-2016, 04:06 PM
I would rather be driving
jpnovak's Avatar
911R hinges. Pull retainer clip, slide out pin. Lift off decklid.
or just flip over onto the rear window glass...
Old 10-14-2016, 08:10 PM
Vintage Motorsport
RichardNew's Avatar
Any number of people are making these 911R hinges. This particular one happens to be the real deal.
Richard Newton
Car Tech Stuff
Old 10-15-2016, 06:27 AM
Shaun @ Tru6's Avatar
For years I've been wanting to make a targa top style attachment. Top of lid pins would fit horizontally into receivers welded in under the rear deck. Then vertical pins fit into holes in the crossmember. RS rubber latches would hold it down. I think it would save a little weight and also allow easy removal of the decklid.
Another "someday" project.
Tru6 Restoration & Design
Old 10-15-2016, 06:36 AM
porsher
Richard Newton
Car Tech Stuff
That would work but I have to say they are kinda ugly.
79 928 Race Car
Old 10-15-2016, 01:22 PM
porsher
Exactly!
I am fitting a rear wing so the deck lid can no longer hinge open.
Someday will happen for me soon
79 928 Race Car
Old 10-15-2016, 01:24 PM
Cool, I hope you can make it work!
Old 10-15-2016, 01:27 PM
cycling has-been
bkreigsr's Avatar
Porsche = Form follows Function.
Nothing about winning beauty contests.
What they lack in style-points is easily made up by the Cool Factor.
Bill K
Old 10-16-2016, 05:03 AM
Vintage Motorsport
RichardNew's Avatar
The ugly hinges are original.
The reproduction ones are much nicer.
It's the old story. Do you restore your car to the way it was actually made or do you restore it to the way you wish they had made it?
Richard Newton
Old 10-16-2016, 07:49 AM
