Oil Pressure Sender Adapter 1973
I have an adapter that looks like a "banjo bolt" with a sleeve that requires 3 sealing rings and it leaks.
![]() I borrowed this photo from another site for part 901-101-175 ![]() It is part 61 in the crankcase drawing link below. 911/912 (1965-1969) - Crankcase Anyone know if this will fit my 73? My sender is 10mm and my adapter is 18mm. |
It is used on the MFI to supply oil to the pump. If you moved from MFI to carbs in the past that would be the plug used with the long sleeve. The T of the era just used the second pictured part to receive the oil pressure bell.
Bruce |
Yes... the part in the second picture is the right one. I probably have an extra if you need one.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
