XDI2 / electromotive wire and relay ...
Hi guys,
as I'm rebuilding the engine, I jump for an XDI2 twin plug ignition management from Clewett regarding the manual, they indicate to have 1 relay for each coil set (2 relay so) pus 3 fuse line. from my point of view it add complexity and parts. I wanted jut to re use the +12V from the HKZ connector for the coils and XDI box power. I suppose the +12V is already protected with a relay and fuse do you agree with me ? or it's not a good idea and I really need to bring +12V from the battery and put the relay and fuses etc ... thanks for your help and feedback |
Vintage Owner
I'd check with Richard Clewitt to be sure, but generally using relays as well as fuses are both good ideas. I run mine with a relay directly from the battery positive, and also a negative wire back to the battery as well.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
I think so
will do it with relay how do you route the wire from the battery (front) to the engine (rear) any easy access ? thanks again |
