-   -   Trouble Finding Replacement Ribe Caliper Bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/932887-trouble-finding-replacement-ribe-caliper-bolts.html)
rollandburn 10-19-2016 01:13 PM
Hi, I'm having a tough time finding the black Ribe nuts/bolts to join wide "A"-type caliper halves together (4 each). The calipers are fully disassembled and split, going for plating next week... I had to cut off two bolts and figure I might as well replace them all which has proved easier said than done! Unfortunately downtown Toronto's Porsche dealership has exhausted both myself and their expertise guessing at various "mounting" bolts they see in the PET.
The car is a 1985 Carrera with what I'm pretty sure are wide "A" type calipers (there are two ~1cm spacers between the halves)... does anyone know the Porsche part numbers or the specs for these 2 sets of 8 bolts with Ribe heads in case I have to buy from a 3rd party fasteners company?
Thanks!
http://forums.pelicanparts.com/uploa...1476907417.jpg
http://forums.pelicanparts.com/uploa...1476907927.jpg
http://forums.pelicanparts.com/uploa...1476907955.jpg
Joe Bob 10-19-2016 01:25 PM
Try Eric Shea, he's on the Pelican board. www.pmbperformance.com
djpateman 10-19-2016 03:53 PM
I looked for years, internationally even, and the best I could come up with was to have them made. The cheapest route is probably to purchase a spare core just for the parts. Eric may have some, but generally that means he has to scrap some cores also.
Jonny042 10-19-2016 05:04 PM
I think Eric's site mentions they are unobtanium. They are M9, IIRC (or is it M7?) not exactly commonplace.
Joe Bob 10-19-2016 05:07 PM
Well if there is a need maybe he could step in, have some made and be America's sole supplier.....
rollandburn 10-20-2016 07:37 AM
Eric was more help in 3 mins than anyone I've spoken to in the past 3 hrs. So there are a few options... none of which would make a concours lover happy (which isn't me so i'm not too bothered).
In short, good luck finding original replacement nut/bolts at 9mm x 75mm w/ 1 thread pitch with Ribe head. Options are...
1. drill out bolt holes to 3/8, hardware readily available
2. buy another caliper and scavenge the bolts
3. go to 3rd party fasterner company, they might have
Strange I called Brafasco and they said, "No 9mm... not possible, there are 8mm and 10mm"... Ugh, haha... I'll keep working on it.
universeman 10-20-2016 07:46 AM
Good luck finding them, if you do find a source, buy them all, and then you can sell them for $20 a piece! ;-D
LM3929 10-20-2016 01:53 PM
I have a set of 85 Carrera caliper cores that may be not worth overhauling if they aren't worth fixing I could sell you the bolts.
lorne m.
pors1968 10-20-2016 03:58 PM
Ill check i think i have these if you still need them pm me it free
Phoenix-MN 10-21-2016 05:40 AM
I went through this as well, 9mm bolts are impossible to find. But you can buy 9mm taps and dies. I took a 10mm bolt and turned it down on a lathe and then ran a 9mm die over it. It doesn't have the ribe head but it fits the caliper without drilling
http://forums.pelicanparts.com/uploa...1477053557.jpg
djpateman 10-21-2016 06:34 AM
Just what I said. Either 7mm or 9mm long lengths AND the 9.6? strength are almost impossible to find; Ribe or otherwise. Ribe is not common, but a Allen key head is as good and much easier to obtain. Even so, it seems custom made or salvage from scrap calipers are the best options. Nice solution making your own from 10mm bolt; were there thread remnants left after machining?
Having dealt with Eric on other projects I have an accurate idea what he would say.
Jack Stands 10-21-2016 07:00 AM
Sounds like drilling for 3/8" Allen head bolts would be a very viable solution if concours isn't a concern. As long as the calipers are apart, a drill press should be all you need. It would be interesting to know why Ate specified the robe bolts in the first place!
donporfi 10-21-2016 10:55 AM
Is it possible to use these bolts ?
https://www.belmetric.com/9mm-metric-hex-bolts-c-506_1027/bh9x125x75f-hex-bolt-109-p-5591.html?zenid=uevqbqvlhsf1a97em4dsao4184
trond 10-21-2016 11:32 AM
you have to wonder what Helmut was thinking when he specified M9 bolts with Ribe heads..... must have been in a foul mood that day
gtc 10-21-2016 11:48 AM
Originally Posted by donporfi (Post 9328280)
I doubt there is enough clearance for the head.
rollandburn 11-10-2016 12:15 PM
A fellow pelican graciously offered to send me nuts/bolts at no cost. What a win, thanks universe and pors1968!
KTL 11-10-2016 01:47 PM
There are so many junk calipers/cores sitting around in people's spare parts collections, these should be rather easy to come by. I have a set of Carrera 3.2 that were seized quite well and I had to grease gun the pistons out of the calipers. Pistons and calipers were in pretty bad shape from years of rusting. So I took them apart and saved the nuts & bolts, along with the spacers. Anybody who needs the nuts & bolts or wants the spacers, let me know.
howiee 03-16-2017 07:19 AM
Looks like I'm in need of a few front and rear Ribe bolts for my re-build too. If anyone has some and they are willing to part with them, please let me know.
If not, I'll go the drill out and bigger bolt route.
Cheers
Jesse16 03-16-2017 08:39 AM
Only a .020" difference 9mm to 3/8". That sounds like the sensible solution for anything but concours. A short headed standard hex/allen would be extremely similar.
KTL 10-09-2018 09:57 AM
Just wanted to update this thread with confirmation that my spare caliper nuts & bolts I mention above were sold. Someone recently asked me if I still had them after he had read this thread.
