-   -   CIS intake reducing rubber sleeves (http://forums.pelicanparts.com/porsche-911-technical-forum/932968-cis-intake-reducing-rubber-sleeves.html)
patkeefe 10-20-2016 08:06 AM
Hi all:
I am considering retrofitting a newer SC airbox (Small Port) to an earlier set of SC intake runners (Large Port). Use of the newer style airbox is set in stone, the runners are in flux. Has anyone ever run across a set of rubber sleeves which convert from 44mm to 38MM (I think those are the diameters of the rubber airbox to runner sleeves I need)? It is an EFI conversion.
TIA,
Pat
john walker's workshop 10-20-2016 08:59 AM
That would be weird.
boyt911sc 10-20-2016 09:15 AM
Intake runners.......
Tom,
I completely forgotten to ship the 34-mm ID intake runner (...2r) I offered you. I have them in the garage right now. Do you still need them? Been distracted with my on going hydraulic tensioners problem. The large intake runners are 38-mm ID (...4R). PM me. My bad. Thanks.
Tony
patkeefe 10-20-2016 10:27 AM
Mr Walker, not so weird. It may be a case of one-of-a-kind application.
Tony, sending you a PM.
Mark Salvetti 10-20-2016 11:37 AM
How about something like these?
Red Silicone Hose Straight Reducer (available 45mm to 38mm)
44mm to 38 mm Silicone Straight Reducer
Mark
fanaudical 10-21-2016 11:09 AM
Those silicone sleeves look like a reasonable approach.
Question: Why use the later SC airbox? Is it a matter of availability, or is there another reason? (Am curious about this one; have contemplated the EFI conversion on my CIS for a while.)
patkeefe 10-21-2016 01:08 PM
I have a late CIS airbox, already modified. I have a turbo, so the outlet size at the airbox doesn't matter. If I use small port runners, I have to port match. My current airbox is Webb stainless steel, which is actually neither big nor small port; something in between, IIRC. As I said, one of a kind.
BTW, the silicone reducers are too long to work.
fanaudical 10-21-2016 04:48 PM
Interesting project.
As an alternative in case you can't find "adapter sleeves": How about building up the small OD to match? I could see finding a piece of aluminum tubing the right size and epoxy/JB-Weld to the small OD, then use the 44mm sleeves.
patkeefe 10-21-2016 06:03 PM
Gates 26391 rubber sleeves may work.
Small port airbox outlet OD=1.555", smal;l port runner OD=1.525"
Big port airbox (Webb SS box)=1.650" OD, big port runner OD=1.770"
What I need is a big port airbox to cut up.
boyt911sc 10-21-2016 07:56 PM
CIS air boxes.......
Pat,
I might have the section of the CIS air box used in EFI conversion that I cut some time ago. The problem is remembering which box it is stored. If it is not located, there are several other CIS air boxes to play around.
Tony
