-   -   Adapting Frame Rails - Help (http://forums.pelicanparts.com/porsche-911-technical-forum/933128-adapting-frame-rails-help.html)
Karter18 10-21-2016 05:06 PM
I bought some Recaro's and they have seat brackets on them for an earlier car. I unbolted the rail assembly and I am trying to remove the vertical support. It appears they had a spot weld on the bottom and four what looks like a stamping to put them on the rails. I drilled out the holes and ground the weld off and no luck yet. Any suggestions from the guru's on here is appreciated. Photos below.http://forums.pelicanparts.com/uploa...1477094692.jpg
http://forums.pelicanparts.com/uploa...1477094737.jpg
http://forums.pelicanparts.com/uploa...1477094772.jpg
I am trying to separate them as it looks like they will bolt right up to my 1987 mounting points.
