-   -   Control Arm bend ? (http://forums.pelicanparts.com/porsche-911-technical-forum/933189-control-arm-bend.html)
Barskov 10-22-2016 12:16 PM
Control Arm bend ?
During frontsuspension overhaul i found that the torsion bar rests on
The right A arm wall and isnt centeret as the left one
I guess this have been bend at some point ?
Anybody seen this before ,
Anyway to correct this or do I need a replacement?
The torsion bar has also taken damage having grinding marks
http://forums.pelicanparts.com/uploa...1477166302.jpg
Trackrash 10-22-2016 12:53 PM
Are you sure it is bent? Try cleaning the spline and switch torsions.
Barskov 10-22-2016 01:04 PM
Thanks Gordon ,
I actually tried to switch bars and turn them with same result
And yes its fully inserted.
DRACO A5OG 10-22-2016 01:18 PM
Okay, Bars are true.
Are you sure there is nothing inside the arm at the end spline cap or maybe end spline cap is tweeked?
