7.0:1 > 11.3:1 > 7.0:1
Steel vs Aluminum trailing arm weight?
By chance has anyone got some comparison weights for the steel versus aluminum trailing arm weight? I'm considering some 1987 arms for my 69 hot rod.
1989 911 Targa |
Thank you for the link, I'm reading it right now. I was aware of the shock clearance issue only with second hand info however.
I have that article, and it's what prompted me to install '74 aluminum trailing arms on my '69. I have to say if I had to do it again, I'd skip it. In my opinion whatever advantages you gain aren't worth the hassle of machining the aluminum ones and dealing with getting the shocks to fit, etc. and all the work involved.
Marv Evans '69 911E |
Under the radar
+1
IMO, if you have a bent steel arm go for it, otherwise, it's more of a hassle than it is worth.
I read briefly the article, is the issue only with the early heat exangers ?
I have a 70 car with a 3.2L engine , heat exchangers . Will I run into any issues? |
Work in Progress
I don't believe it is as big of a problem on 70 and up cars. I have a pair for sale if your interested send me a pm.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Under the radar
There are some threads here covering it. I'm not sure what the advantage is.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 10-22-2016 at 08:45 PM.. |
Well, it's sounding like a waste of time for a 10 lb saving, also considering it's only a street hotrod . I think I'll stash the aluminium arms away for the time being.
I did the conversion to my 72 years ago on my weight reduction campaign. The real advantage for me ( I ruined two wheel bearings because of a slightly bent steel arm) was the bearing in the aluminum arm is larger.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
