-   -   2.7 cis to carbs? (http://forums.pelicanparts.com/porsche-911-technical-forum/93337-2-7-cis-carbs.html)
jhelgesen 01-07-2003 06:33 AM
2.7 cis to carbs?
Hey guys, couldn't find the answer I was looking for on the search, so I figured I should ask.
I'm looking at a 2.7 cis engine. Looks well cared for, pop of valve, tensioners, 11 blade fan, turbo valve covers, etc. Working on finding out about the head studs and maybe a leak down test.
Engine was running when pulled from car, but was coughing and making black smoke under hard acceleration. Been sitting for a few years now.
Is it worth trying to fix the cis? Or, I have an excellent pair of zenith carbs I could use and pull off the cis. This is all depending on the condition of the engine though.
Any idea of value of the engine?
thanks,
RoninLB 01-07-2003 06:47 AM
Well, IMO, if it has 100k the cast pistion are probably worn.. not that you couldn't still clock some miles.. a correct full rebuild is big bucks.. forged RS pistond and a E, solex, or S-cam w/carbs and SSI is a fun engine.. CIS can be big bucks to repair the fuel dist.. gas turns to a varnish after a while.. so clogged fuel dist is a considerstion.. if your thinking at a partial rebuild? might be better w/used running 3.0 or 3.2.. I never tried flushing a fuel dist
