Power window relay
1986 911 Cabriolet.
It seems that my electrical circuits differ from the Bentley diagrams. I'm guessing this is common. Anyways, I have been working on getting everything working again. Wrapping up repairs on the fresh air blowers, finished repairs on the heater system and fixed issues with the wiper lever. Now I am tackling the power windows and the washer system. I have been having a problem with a draw on the battery when the ignition is off. While checking out the (behind the gauges) relays, I found that one of the relays is hot to the touch all the time, even with the ignition off. It clicks when I turn on the ignition. Bentley says it is the power window relay. Opened it up to find a large resistor near that area where it is hot. I'm thinking this may be the problem with the battery draw. I pulled the relay and my windows still work, and they have always worked with the ignition off. Is this right? I'll get to the washer system gremlins later. |
Relay.
PM sent.
Gerry |
do your interior lights work properly when you open both doors?
The relay keeps the window circuit "alive" after the engine's turned off until you open a door -- no trigger that the door's open and the circuit remains alive. |
Yup, if the windows work after the door is opened, you will have a draw that will kill the battery in a few days. Either clean the contact point of the door switch, or better yet, get new ones.
Very helpful thread. I think that I may have the same issue (1986 Cab also!).
Thanks to all. |
Well, I cleaned the contacts on both door switches. The interior light works properly, i.e. it lights when either or both doors open and shuts off with the doors closed. However, I can still work the power windows with doors open or closed. If I understand it correctly, with the door open and ignition off the power window should not work. Is that correct? I would think that if the door switches worked correctly for the interior light why would new door switches change the situation. Am I missing something?
I have traced the black wire from fuse block 3, fuse 1 to the 86b contact of the power relay. GOOD
My interior lights work properly, door switches work also. |
Please refer to the new thread.
"Calling all electrical experts" |
| All times are GMT -8. The time now is 11:23 AM. |
