How in the heck do I get behind these switches?
Hey Guys,
Did a quick search and didn't see anything, so I figured I'd pose this question. How do I access the wiring behind the switch cluster above the radio? I am in the process of relocating my defrost switch to that area and cannot find an entry point from the back side of the dash to connect the wiring harness. It looks like there might be a point of egress from the AC vents from above, but that is posing difficult to remove without damaging. Any ideas? Alex |
Try and pull some gauges in the dash. Otherwise thru the trunk and remove the fresh air assembly....
+1 thru frunk behind the fresh air components, unfortunately. Take careful note of wiring position prior to disconnecting them
Good call! Thanks gents!
| All times are GMT -8. The time now is 07:25 AM. |
