polizei's Avatar
Strange vibration and rubbing sound at speed
Hey Guys,
I've had my 3.2 Carrera out a couple times over the past week. At 60 mph, I feel a vibration thru the steering wheel and hear an oscillating noise that sounds like two things are rubbing together that shouldn't be. Any ideas on where to start looking?
Thanks,
Andy
Andy - 1987 911 Carrera Coupe
Old 11-01-2016, 07:35 AM
cycling has-been
bkreigsr's Avatar
Here's a few speed-related things to look at.
Wheel weights loose?
Tires balanced?
Flat spots?
Bearings properly adjusted?
How much pad lining do you have?
Bill K
Old 11-01-2016, 08:09 AM
Elombard's Avatar
My emergency brakes rub cuz i have them adjusted a little too tight. Need to back them off. No vibration but scraping sound
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-01-2016, 08:16 AM
Administrator
Luccia at Pelican Parts's Avatar
Are you able to pinpoint where the oscillating noise is coming from? Front/rear? Have you done any maintenance to the vehicle recently, like new tires/alignment, etc? I'd also recommend checking your wheels to make sure they're in good condition and not bent. This individual may not have your exact issue, but it has some good suggestions to check over as well: Front Suspension Vibration at Speed. I'd definitely check out wheel bearings and other suspension components. Hopefully more Pelicans will pop in and give you some additional advice as well. Good luck and let us know what you find out.
Porsche 911 Front Wheel Bearing Replacement | Pelican Parts DIY Maintenance Article
Old 11-01-2016, 11:30 AM
When driving at a constant speed, slowly turn the steering wheel right and then left. If the vibration/noise changes pitch, the likely culprit will be a wheel bearing.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-01-2016, 11:37 AM
I know it sounds insultingly obvious, but it happened to me: take a look at the tires, particularly the inside edges. I had this happen, and was thinking of all sorts of suspension related explanations. Turns out the tires were worn down to the threads on the inside where I couldn't see from the side.
Old 11-01-2016, 11:40 AM
