Glasgow 911SC's Avatar
Post How To Install Stone Chip Gaurds
I want to fit these to my narrow bodied car but they don't seem to go on flush with the wheel arch line when the bottom edge is level with the rubber sidestrip on my car. Does the bottom edge go above the rubber strip or underneath it? Do you get the arch side of the gaurd lined up right and hope the bottom edge matches up? Any close up pics would be appreciated!
Thanks.
Old 10-18-2001, 04:24 AM
jsmarcus's Avatar
Remove the rocker end cap (2 philips head screws) and pull a bit of the rubber trim away. The best bet for knowing how to put it on is to look at some photos....I'll try to send you one.
Before afixing, make sure you wash the area and remove any wax. I washed the area with a little ivory liquid soap. Then, make sure the entire area is completely dry. Line up the bottom of the guard with just under the rocker molding. The edge by the wheel well should be just before the curve. Affix from bottom up, making sure there are no air bubbles. I used a clean shop rag and as I affixed, I rubbed upward to make sure it was evenly affixed.
That's it. There's really no secret to it and it looks sharp!
Josh
Black on Black '84 Carrera
Old 10-18-2001, 05:12 AM
Hey guy's you can get the Magnetic type as well.. which are great when waxing the car the pull right off! just an option rather than glueing them on.
Cheers, Eric Mckenna
Old 10-18-2001, 06:15 AM
VenezianBlau 87's Avatar
Post
Eric, where can you find those magnetic ones?
I made the sticky ones fit pretty well. Luckily, the material "gives" quite a bit and you can "make it" follow the wheel arch. Mine did not match the arch perfectly in their natural shape. BTW, replacing the rocker panel rubber really makes a sharp difference. Takes a little patience, tho.
Bob Sauerteig
'87 Coupe
Old 10-18-2001, 06:28 AM
MarkY's Avatar
Send a message via Yahoo to MarkY
Post
You can get the magnetic ones from www.magbra.com
I have them on my 1988 and love them. Have driven over 100MPH with them and they won't come off. I have the whole mag bra setup.
Old 10-18-2001, 07:00 AM
MIK911's Avatar
Question
How to REMOVE these glued on stone guards? Any suggestions?
Thanks.
mike
Old 10-18-2001, 10:12 AM
Eric Coffey's Avatar
Mike-
You might try a heat gun to remove them to slowly peel them off. You will most definitely need to use some form of adhesive remover once they are off as well.
-Eric
Old 10-18-2001, 11:08 AM
daz911's Avatar
Post
Guys - I have the magbra ones - I recommend these os you can take them off to wak or show the car. I also have driven over 120mph and they stayed on,
... Thinking about the full set up, have a normal colgan bra for the front and mirrors at the moment. I have converted a few people to these !!
D ! .... ('82 SC Targa)
My SC Page:
geocities.com/p911scuk
Old 10-18-2001, 04:20 PM
