urseppos's Avatar
Weber PMO Manifold Crack
So I just noticed this crack as I was cleaning around the carbs and engine bay. I have not noticed any fuel leaking but should I not drive her until it is either fixed or a new manifold ordered ?
Old 11-05-2016, 01:58 PM
Looks like someone used the wrong fitting. Does it leak? Looks like the fitting is for power brake booster to me. If everything is sealed properly and no leaks I would just keep an eye on it and run it as is. My 2 cents.
Old 11-05-2016, 02:14 PM
That can create a vacuum leak and thats damned serious.
I would either have it welded, or perhaps use a dab of JB Weld.
Naturally, replacing the manifold is a good option too, however I would get another fitting so you don't run the risk of having this recur.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-06-2016, 12:44 AM
