How to remove shroud behind fresh air blower?
Hey Guys,
I'm trying to gain access to the intermittent wiper relay on my '87 Carrera. Following Bentley's suggestion, I removed the fresh air blower, but the large black plastic shroud behind the blower is still blocking access to the relay. I don't see anything in the Bentley manual that explains how to remove the shroud. Can someone help? Thanks! ![]() Sorry for the dark image - I didn't realize how bad it was until I posted!
Andy - 1987 911 Carrera Coupe |
Yeah the drain hose is the key.
I think you pull it gently from the bottom - the bottom rotates forward and up as it comes out. Going in is even more fun
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
ahead of the curve
did you try to pop a gauge out and access it through the hole?
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone ![]() |
^^^ Don't tell him after the fact it's right behind the Clock and he could have changed it in 15 min...
Derrick |
I think it's doable through the clock hole. However, now that the blower is coming out, there are some things that you could do while in there.
1. Reverse the parking of the windshield wipers to passenger side 2. Make sure your cigarette lighter is working, also bulbs in your fog light and rear defrost switches. 3. Lube your heater control cables and pivots. 4. Lube your blower motor shaft Fresh Air Blower Squeal Fix Maybe a few other things. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 03-06-2017 at 09:14 AM.. |
Occasional User
I am struggling with a wiper switch problem, so am bumping this thread. I thought there were two relays - First one you access by removing a gauge, and pulling out, or by reaching in through luggage compartment. The second one is up by front latch / battery. Is there a third behind the ac/ heat tubes?
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
