Targa/CabOwners: Read! Just Installed Triangulated Camber Truss
From Stable Energies. I am not given to hyperbole over products--I'm really quite sceptical over BS claims and such.
THIS THING MADE A **PROFOUND** DIFFERENCE IN THE FRONT-END FEEL AND OVERALL RIGIDITY OF THE CAR. *PROFOUND*. I am really dead serious. It should be an absolute must for open-roof 911's. You should simply not consider anything but a triangulated brace. It's truly a big-time *WOW*, obvious after rolling 5 feet. And, my car is structurally very sound and stiff for a Targa. Those who say they can't tell a difference on the street are flat wrong or not sensitive to what their cars are doing. The difference is marked during regular stop and go driving.
Kristian |
Thanks for your insights. You are the first that I know of to actually install one. I think this design is the best way to go instead of just one bar attaching to each pillar top.
Did you get the steel or the aluminum version? How easy was the installation. Randall
Randall 1988 911 Cabriolet (SW Chip) 2000 Honda Civic (4dr wifey mobile) 2001 Honda S2000 (daily driver) 2003 Honda Odyssey (family truckster) 1978 911 SC coupe (Sold) My 911 Cab Pics |
Formerly bb80sc
Our buddy Chuck has some good tech info on his site on his product, which is probably similar.
http://www.elephantracing.com/suspension/strutbrace/strutbrace.htm I have been thinking about one for my 80SC Coupe...
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
I'm sold on the bar, and I'll probably get one this spring. I'm really curious about the body brace though - the one that attaches at the seatbelt points. Does this help at all?
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
I bought one used from a racer on Rennlist and also noticed a significant difference during last year DE season. With the same rubber, the car turned in more predictably with a noticable decrease in understeer.
RE: the body brace....the Brey-Krause Harness guide bar incorporates this type of system which firms up that particular installation. I don't think it necessarily stiffens the chassis though. Past threads have detailed that the Targa body has been stiffened significantly and weighs nearly the same as the coupe because of this. I don't find any noticable flex with mine..tracks just as fast as the coupe's.
12' GT3 18 991S Last edited by avi8torny; 01-09-2003 at 04:06 AM.. |
Kristian can you post a URL?
I have a Stable Energies brace in my Coupe. (Sorry, Chuck, I bought it before you put yours out).
It is stiffer, but not nearly as much as in a cab, I'm sure. Here is a pic:
the url is www.stableenergies.com
Drove it 100 miles last nite--32-35 degrees, perfect stars, top off--it is NOT subtle, boy, what a difference in overall chassis stiffness, reduced understeer, more precise high-speed cornering--it's a changed car.http://www.stable-energies.com/stable/camber.html
Kristian |
I have had the AJUSA strut brace in my car since I first purchased it. Has anyone used the "regular" straight strut brace and then moved to the triangular brace? I would be interested to hear some real life comments regarding the performance between the two.
Kristian |
Senior Member
Tyson told me the same thing. In fact his girlfriend/passenger also noticed and commented. Apparently the difference is dramatic. In non-coupes.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Formerly bb80sc
Kristian, how was the installation? What do the angled parts bolt to? Any chance of anything tearing out over time? Got any pics?
thanks!
Kristian--
You've convinced me. It's on my project list.
Dan Morissette '85 Guards Red Targa 911 My Owners Gallery Page Non illegitimi carborundum |
I've got one (stable energies) sitting in my garage. If anyone wants to buy it used, email me.
If you're interested in the Elephant Racing triangulated brace (much lighter, more ridgid) you can get them from Pelican.
Chuck Moreland - elephantracing.com - vonnen.com |
And, I got their aluminum version--what I can guarantee you is that weight is not a concern. A couple, or 75, pounds more or less just doesn't really make a difference in reality when the whol thing weighs 27-2900 lbs.
Kristian Last edited by kristian85; 01-09-2003 at 09:33 AM.. |
Hey Magilla,
Nice looking brace. Funny how the carpet cut on the passanger side looks better than the drivers side. ![]() Seriously, how do you know how much to tighten up the center nut? It seems to me if it's too loose, it won't be as effective and if too tight could throw off your camber. Next question: Chuck, does your fit the back of a 914 like the Stable Energies brace? What's the difference between the two?
David 1970 914/6 RustoMod 2015 Mercedes E400 |
Kristian |
I'm curious - why the realignment?
Argo 88 Targa |
For an explanaition of triangulation and how it creates ridgidity, check this: http://www.elephantracing.com/techtopic/triangulation.htm Proper triangulation puts all members in pure tension or compression, no bending loads on the members. The SA diagonals tie to the center of the floor and attempt to bend it. This compromises the ridgity of the design. With a proper triangulated design, a second diagonal brace does not add any ridgidity. Properly sized members provide adequate strength with a single diagonal, and with less weight. Kristian, you are obviously pleased with your purchase and I don't intend to take the wind from your sail. The SA product is certainly more ridgid than a regular single-bar brace. Your driving experience confirms this.
