eBrake
I tightened my eBrake last fall because it wouldn't actually stop my car from rolling down hill when parked. Now, I am noticing a little rubbing noise when I take off from a dead stop. The noise goes away after I get up to 10mph or so. Did I over-tighten my eBrake? What else could it be?
(I would go out and lift up the old pCar to see what's happening but it's freezing outside. Trying to get ideas before I jump in.)
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 01-08-2003, 08:47 PM
How did you tighten you E-Brake?
There are two separate things that need to be looked at. If you simply tightened the E-Brake springs for each rear wheel in the rear discs, then you may have over tightened them. The spring simply sets the lowest limit for not engaging the e-brake (if this makes sense). So you want the e-brake off, and the two springs adjusted so that they are just off impeeding the motion of the rear wheels.
If you found that you needed more than several clicks to fully engage the e-brake then you actually need to get under the car, and adjust the two lines that run to the rear wheels. At least I believe this is the case (because I need to adjust my lines as well)
1977 3.0l Targa Carrera
Old 01-09-2003, 04:57 AM
Bones's Avatar
GS print this out
http://www.pelicanparts.com/techarticles/bob_tindel/e-brake.htm
Old 01-09-2003, 05:20 AM
