-   -   What's the tool to remove these? (http://forums.pelicanparts.com/porsche-911-technical-forum/935637-whats-tool-remove-these.html)
sempaipaul 11-13-2016 03:48 PM
Item #4 and #17 ---- appears to be the same tool?
https://s12.postimg.org/3woj3jdv1/image.png
Paul
BK911 11-13-2016 04:05 PM
If by same tool you mean big pipe wrench, then yes.
But there are special tools for both.
Search for ball joint nut. Plenty of opinions on removal.
Ayles 11-13-2016 04:15 PM
There is a guy selling a nice looking version here:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/916403-fs-911-front-ball-joint-nut-socket.html
Sebscst 11-13-2016 05:12 PM
I removed mine with an air chisel it did not damage the nut.
michael lang 11-13-2016 05:12 PM
#4 & #17 are not even close to one another. #4 is a wrench extension that loosens/tightens the big nut at the top of the strut tower that holds the insert in place. It's open in the middle so that is can slide over the strut insert. #17 is the ball joint and the socket that loosens/tightens the ball joints look like the top of a castle or the Rook piece in a chess set. The tools don't even look like one another.
boyt911sc 11-13-2016 05:19 PM
Special tools for #4 and #17.............
Paul,
I have the steering ball going removal tool (#17) and probably the front strut insert gland tool (?) too. Could you post a close up picture of the front strut gland you are removing? The tools were used for my '78 SC suspension upgrade many years ago. I could mail them to you.
Tony
michael lang 11-13-2016 05:31 PM
This is the tool you need to take the nut off at the top of the strut assembly, #4. Since I have not yet replaced the ballpoints in my car I have not had to buy that tool yet.
http://uploads.tapatalk-cdn.com/2016...de8779a08e.jpg
The link attached to this thread gives you an idea of the tool used for #17.
I hope the photo helps see the difference in the two tools.
Which parts are you trying to replace or are you going after both? I'm not that far from if need to use my strut tool.
john walker's workshop 11-13-2016 06:01 PM
The abovet tool is just for Bilstein retainers.
Joe Bob 11-13-2016 06:05 PM
Yep, pipe-wrench for me as well....
sempaipaul 11-15-2016 04:36 AM
Originally Posted by boyt911sc (Post 9358123)
Paul,
Tony
Tony,
Here is what the Boge gland looks like:
https://s12.postimg.org/xe7semzsp/image.jpg
https://s12.postimg.org/cvcw9klvd/image.jpg
I would really prefer not to use a pipe wrenching able!
Paul
john walker's workshop 11-15-2016 04:48 AM
Big-ass channel-locks is what I use for Boges. No shame. Gotta get em off. You ain't gonna reuse that Boge cap anyway. You're going to put Bilsteins in if you're smart and use the above Bilstein tool, which of course doesn't come with the inserts and has to be had from Bilstein. They used to come with them.
75 911s 11-15-2016 06:06 AM
To take off:
http://forums.pelicanparts.com/uploa...1479218626.jpg
To put on:
http://forums.pelicanparts.com/uploa...1479218803.jpg
boyt911sc 11-15-2016 07:28 AM
Using improvised tools.......
Originally Posted by sempaipaul (Post 9359898)
Tony,
Paul
Paul,
There are several ways to do things. JW and Duane have given you good examples. I had Bilstein inserts in my '78 SC and this was what I used:
http://forums.pelicanparts.com/uploa...1479223139.jpg
For the Bilstein insert removal, I used an old Bilstein gland and made a positive version to remove and install the gland with the help of a spanner.
http://forums.pelicanparts.com/uploa...1479223154.jpg
Don't worry about using a big channel lock plier or a pipe wrench. Wrap some masking tape on the gland to minimize the abrasions if that is your concern or find the appropriate tool.
Tony
GH85Carrera 11-15-2016 08:28 AM
If you buy the Bilstiens and you don't get a tool, contact Bilstien. They will mail you the tool for the top nut for free. At least they did a few years back when I did my suspension refresh. The bottom nut is a different tool.
