Rear Quarter Windows won,t fit
Hello !
Windows are to tight can,t get them properly in place, Anyone that have had the same problem ?
They are the opening type.
New gaskets , frame and window ,
New gasket , frame body.
Bought gasket at Pelicanparts, OEM.
Bouht new ones here in Norway, Original Porsche, same problem.
Hope that one of you have the answer to my problems.
Regards Řistein
Oistein Norway
Old 11-14-2016, 12:34 PM
I had this exact same problem and recall seeing other threads with the problem as well.
They will fit but need some help. Use dishwashing liquid or some sort of lubricant around the seals. Get your garage nice and warm. Carefully push them in, CAREFULLY.
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 11-14-2016, 12:39 PM
Mick_D's Avatar
Definitely don't get a big hammer.
Old 11-14-2016, 12:42 PM
Like 'matthewb0051' said....LOTS OF LUBE......and get a friend to slowly and gently pull the inside latch closed while you push from the middle and end (opposite of the hinge). Go SLOW. Then, don't open them until next summer!!
Marc Zurlinden
zurlindengruppe.com
Old 11-14-2016, 01:50 PM
I put my whole window in bucket of really hot water, then installed them, shut them, left for couple days before opening. All good!
Old 11-14-2016, 02:48 PM
The 8th grade boy in me is dying to make a comment on this...
+1 on close them and leave them closed for some long period of time.
1969 911E SOLD
2002 996 Cabrio
Old 11-14-2016, 02:57 PM
Banned but not out, yet..
RSBob's Avatar
We have two different interpretations of your problem.
1. You cannot close and latch the window, or
2. You cannot get the seals to fit in the window frame.
When I backdated my 82 to opening rear windows I installed new seals and they were tough. I ended up using lots of dishwashing soap and bicycle tire levers to get the seals/gaskets to fit. Like the others said go slow and use patience. Also the Windows didn't want close, so I pushed slowly as my wife pulled the inside latches and finally got them closed. I too left them latched closed until they relaxed. With time they became much easier to close.
Old 11-14-2016, 06:08 PM
It,s this:
1. Can not close and latch the window
Will try all tips and let you know.
Thanks Řistein
Oistein Norway
Old 11-15-2016, 12:04 AM
Hello !
Thanks for help everyone !
Windows are now closed an latch inside locked , will not open them until 24th of December, at least.
Maybe next summer
Regards Řistein
Oistein Norway
Old 11-15-2016, 10:51 AM
