-   -   need help removing back seat (http://forums.pelicanparts.com/porsche-911-technical-forum/935869-need-help-removing-back-seat.html)
Trakrat 11-15-2016 06:40 PM
I am having problems removing the flathead screw that the back seat rest is attached to.
It is pretty rusted looking... any suggestions on how to loosen this screw?
SpyderMike 11-15-2016 07:45 PM
PB Blaster and an impact driver I bought from Amazon for about $20 got mine out.
75 911s 11-15-2016 07:53 PM
I think I put the biggest screwdriver with a square grip I had in there, then I put a giant pair of vice grips on the square grip and then a cheater bar on the top grip and popped it loose.
Lyle O 11-15-2016 08:02 PM
I'm with SpyderMike on this...I used Kroil, an impact driver, and a BFH.
Trakrat 11-15-2016 08:03 PM
I'll give those suggestions a try. Thanks!
Ryce Stallings 11-16-2016 01:28 PM
Use a wood chisel as a screwdriver. Get one a wide as the slot in the screw. It will transfer the torque better.
Trakrat 11-16-2016 04:42 PM
OK.. after trying to figure it out I went with a large washer held on with a pair of pliers. This gave me enough grip and enough area within the screw to turn it enough to break it loose and unscrew the rest of the way with a screwdriver.
