Change/upgrade "eyebrows"? around the headlights
Not so much a comment as a question: I'm looking at a classic F-series 911 and am seeing a lot of them in the US which have larger silver fittings "eyebrows"? around the headlights. Are these easily replaced with the more elegant and recessed fittings? Is this costly?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 H4 Headlight Upgrade | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
I am not 1005 sure. A kit may be available to make it easy. Give our parts specialists a call at 1-888-280-7799.
I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick |
i presume you mean changing from the US sealed beam versions to the H1 or H4 set ups? yes its quite easy and i wouln't lose any sleep on it with regard buying a car or not! Focus on the engine, gearbox and how straight the chassis is, you'll have no problems with the lights
| All times are GMT -8. The time now is 08:18 PM. |
