-   -   Torque value for CIS (930/SC) manifold stud? (http://forums.pelicanparts.com/porsche-911-technical-forum/93606-torque-value-cis-930-sc-manifold-stud.html)
cowtown 01-09-2003 09:28 AM
Hi everyone,
I'm trying to find the torque value for the 12 nuts that fasten the intake to the heads on a '77 930.
The nuts attach to studs passing through the intake, phenolic injector blocks, and into the heads. I <i>think</i> the value for the 930 would be the same one used on SCs...can anyone help with a reference or the correct value?
I must just be missing it - can't find it in the shop manuals or spec book. http://www.pelicanparts.com/support/smileys/dom.gif
Thanks,
Colin
john walker's workshop 01-09-2003 11:55 AM
i've never seem any torque value for the 930 intakes. they're usually quite loose and i just tighten them up by hand when doing a tuneup. the studs are real long, so they would probably be stretched if you used SC values.
cowtown 01-09-2003 05:03 PM
Okay John, Thanks! I'll just snug them and keep an eye on them
Colin
speeder 01-09-2003 07:50 PM
Colin, Phenolic=plastic? I'd imagine that the spec is real low torque if there is one, (spec). :cool:
cowtown 01-09-2003 08:53 PM
Yep, plastic spacers, about 2" high, which the injectors screw into. They look pretty tough, but I'll keep the torque low. :)
john walker's workshop 01-10-2003 08:57 AM
those spacers often have cracks in them, against the heads. some quite large. they also should be resurfaced if reused. the ends get quite irregular. you can get billet aluminum ones, but they're pricey.
cowtown 01-10-2003 05:44 PM
Didn't know they had to be resurfaced...I will do that. Thanks again John.
I have checked very carefully for cracks and they look OK in that area.
Colin
