Fix for broke hood lock stud?
Hey guys
I snapped the left hood lock stud in half while over tightening the latch hook assembly. Theres barely any thread left to get a nut on there. Anyway to fix this? Is it a cut it off and weld on another type of fix?
1977 911S(c) with an 81 SC engine Anthrazite grey metallic
1979 911SC Coupe in Sky Blue - SOLD
1976 911S Widebody Targa - SOLD
Old 11-18-2016, 05:08 PM
Nine9six's Avatar
Is the top of the hood on the opposite side? Like to see this with the latch removed.
Trying to determine if there is anything to drill and tap into.
BTW, what size is the stud?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-18-2016, 07:07 PM
disband
juanbenae's Avatar
take the latch off completely and then try to get a better grip on the remaining bolt portion with a very good set of needle nose vice grips. I might also reattach the removed nut & retighten it with an over sized washer to keep the floating flange piece hidden in the hood somewhat stable while you try to back the broken piece out. try to use a screw driver or such to further steady the internal flange as you try to back your mistake out with the vicegrips I reference
or epoxy it to the hood and rely on the receiver & cable portions of the system to adjust your hood starting tomorrow after the epoxy has cured....
Old 11-18-2016, 07:46 PM
its a stud not a bolt. I dont think itll unscrew. If it were a bolt you could use a reverse drill bit with a limiter on it so you dont drill through the hood. welding on might result in burnt paint on the topside you will have to be carefull. you could try to drill and tap it for a bolt but if you even touch the outer skin its going to leave a mark. your going to have to cut off the tap so theres no point or use a blind hole tap. i think id weld a stud on that seems like to best way to keep the hackjobery at a minumum. theres no easy fix besides the glue it on method
Old 11-19-2016, 07:13 AM
You will need to find someone with a stud welder, similar to what body shops use to weld pull pins to get dents out.
206 637 4071
Old 11-19-2016, 09:53 AM
Yes top of the hood is on the other side
Old 11-21-2016, 01:01 PM
Ugh, thanks for the info. Cant believe i over tightened this nut
Old 11-21-2016, 01:03 PM
