Oil leak - Cylinders 2 and 3
This is my 1983 Cab SC.
I have developed a leak that really messes up my SSI and the smell is just awful. I have read lots of threads and this "could" be from the "triangle of leaks". Has some been able to check the triangles without dropping the engine? I have used a flashlight and mirror and those areas appear to be dry. I am also about to remove the valve covers to check the rockers. Any other ideas where this leak is coming from? The red mark in the photo shows the path of the oil leak. Thank you Windsor ![]() Last edited by cab83_750; 11-18-2016 at 02:57 PM.. |
... and I just installed the engine from a recent clutch job. The leak was already there before the clutch job and it was my mistake forgetting to check where the leak was coming from.
To my consolation, the engine was not clean enough for me to pinpoint where the oil was dripping to. Now, it's a matter of where. |
Are the SSI's new? Mine smelled horrible for a long time till they burned off.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Nah! I have had them for years.
And yes, my emmission is still within limits. ![]() |
My guess would be the leak is from one of the case bolt o-rings.
Thanks |
