motor number gurus 3.oL SC
in doing some research here I ran across some of grady's old posts on engine numbers and have a question maybe someone can clear up. in the example posted the 80 SC motor number was as follows 6401025
as described the 6= 6 cylinder, 4= engine type (more on this later), 0 = an 1980 3.ol & the last four the sequential motor serial number. so, does the "4" engine type reference the higher compression, smaller heads & O2 sensor of the 80-83 models? I ask this because looking over the cert of authenticity from my old 78 3.oL ive found the following number ID, 6580083. as I decode this I find the 6 cylinder motor, but the motor type, 5 has me wondering does this designate the 78-78 3.oL motor with air pump & the bigger heads? additional info, this was a California car so maybe the 5 has something to do with that? ive noticed in my research that the 74-77 middies have a specific CA specific motor designation numbers. did the 3.oL power plants have the same differing designation for CA models? also, as I understand it by 1980 all the SC had the 50 state designation. any truth to this? per the rest of my old 78's numbering makes perfect sense, the 8= a 78 and the sequential number of the 83 3.oL produced. fun fact, my older 78 had the vin number of 9118200049, meaning the 911 model, 82 designating a coupe, and the sequential being the 49th SC coupe produced. I really should not have cut up & caged it to go racing in such a car with 80k miles,,, eh? I ask because I'm going to look at a transplanted 3.oL car tomorrow that the guy has no idea as the year of the motor is. any help would be great, it's times like these I really miss not being able to email grady directly... RIP sir! t |
that chart also confirm my assumption that the "5" motor designation is for the 78-79 big head version & the "4" is for the 80-83 02 sensor, higher compression models that closed out the 3.oL run... t |
| All times are GMT -8. The time now is 02:08 PM. |
