-   -   Throttle response (http://forums.pelicanparts.com/porsche-911-technical-forum/936601-throttle-response.html)
sylvester 11-22-2016 02:36 AM
Throttle response
Hi.. I have a 79 SC coupe.. my question is... what makes the throttle response so quick on these older 911s. its kinda quick like riding a motorcycle. just curious thank you very much.
T77911S 11-22-2016 04:58 AM
if it is CIS, the vacuum controlled WUR helps. its a fairly light car, manual trans which means a more solid link from engine to tranny, no smog crap.
CIS was not a great performance system by any means although it did come on very expensive cars
carbs have much better throttle response
JMO
Tippy 11-22-2016 05:46 AM
I've never heard of a quick throttle responsed CIS?!
porschenut 11-22-2016 07:52 AM
This is a joke, right? CIS has the worst throttle response of any 911 ever made. Even the EFI 3.2s have lousy response. Good response is only had with carbs or MFI on the longhood cars. Or carbs or ITBs if installed on a later car.
Tremelune 11-22-2016 09:37 AM
Independent throttle bodies.
Getting ITBs on a Porsche is usually done by stealing parts form larger motorcycle engines. Nobody has a plug-and-play kit for it, though it is being worked on:
http://forums.pelicanparts.com/porsche-911-technical-forum/898159-next-big-thing-3-0-efi-itb-w-rasant-engine-management.html
DRACO A5OG 11-22-2016 09:48 AM
Have to agree 3.2 stock is really doggy but with properly timed 964 cams and SWChip, It makes a vast improvement.
+1 on SC, light ( lighter than 3.2 for sure ) car so it will be quick :D
Josh D 11-22-2016 11:05 AM
Advancing the ignition timing on a CIS 911 definitely quickens the throttle response. It isn't all the CIS fault.
Bill Douglas 11-22-2016 11:06 AM
It's a particuarlly good year for a 911SC, that may explaine the thottle response being excellent.
regards, Bill 1979 911SC :D
prschmn 11-23-2016 04:41 AM
Could be this car has an Aluminum pressure plate-less rotating mass helps a lot. Any intake with the butterfly farther from the valve has inherently slower response-hence ITBs or carbs make a huge improvement. Increased ignition timing can help but at the risk of detonation.
garment 11-23-2016 06:58 AM
How does one know what the "correct" throttle response should be? I associate response RPMs/where in the power band the car is when accelerating (which I guess is just one variable).
Tremelune 11-23-2016 07:14 AM
It's not so much a correctness as it is that you want minimum latency between when the throttle moves and the engine is at the speed it will eventually reach for that throttle position. Well, I do. This is ignoring the downsides of lightweight flywheels etc, but...This is pretty close to ideal:
https://www.youtube.com/watch?v=XRXwWbo_mX0&t=59s
The only real value I'm aware of is during shifting, and most of these cars rev fast enough for the speed that you should be shifting at, so...
914efi 11-23-2016 07:31 AM
My CIS 911 3.0 has better response than my EFI 944...
911 has a lighter flywheel for sure, but the broad-brush maligning of CIS is incorrect in my opinion. Properly tuned it is quite good as the OP states.
