spark plug question
Getting ready to seal up valve covers etc - quick question on spark plugs.
Running a crankfire ignition (74 case - vintage racing build) and was wondering if any one had ideas on spark plugs - do they need to be anything special - I should have kept them when I tore the engine down but was a complete rebuild and just pitched them. Do I run the gap in the handbook or should I gap out a little? Thanks -
Old 04-09-2018, 10:12 AM
rsscotty's Avatar
As far as getting any recommendations on spark plug heat range from the amount of information you have provided.......good luck.
Maybe Steve @ Rennsport would chime in and lay down the list for you.
Old 04-09-2018, 01:43 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I say factory recommended plugs with a wee bit fatter gap. Like thirty five to fourty thousandths.
Aftermarket ignitions talk of sixty thousandths but that highlights every weak point in your secondary ignition.
Once you get some burn time read your plugs and make a call. There are myriad posts here and elsewhere explaining that procedure.
1981 911SC Targa
Old 04-09-2018, 02:02 PM
Under the radar
Trackrash's Avatar
If you post the details of your build in the Rebuild Forum, you may get some advise.
FWIW, I use NGK BP8ES in my 3,0 carbed hotrod. I'm using the CDI and stock gaps.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-09-2018, 03:11 PM
Thanks - not sure what is needed but here are some specs:
10.5 CR; Elgin 310/296 profile cams; twin plug; crank trigger ignition.
Hope that helps - I rebuilt the engine and comfortable w/ that but struggling with the ignition and the older nutek/crankfire system in the car (I did not install).
Old 04-09-2018, 08:37 PM
T77911S's Avatar
you need to start with a cold plug and work your way up in heat range to find one that works best.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-10-2018, 03:45 AM
