Soak with Oil Eater rinse with hot water, connect a hose from your water heater if it is in your garage.
FYI.... Home Depot shows they have a SKU 343863 but no stock model #709-QT in the store (or in a store within 100 miles) and it can't be shipped. I went to my local HD to double check and they can't order it. They said it is not available to them now - and often the web info. doesn't get updated. I sent a message to the Karnak Corp. asking where I can get this stuff near me. |
id say burn it off.
the carpet is a great tip. noted.;) |
A shop cloth wet with ATF or Marvel Mystery Oil. Use with a stiff parts or paint brush (shorten the bristles). New vs old oils combine to loosen crud. Wear gloves and have a large pan under the area to catch excess lube, dirt, grease, leaves, stones, etc. Aerosol cleaners are a waste of propellant.
Sherwood |
On occasion, I use a product called ZEP A-LUME. You can buy it at large truck supply houses for under $25 for a gallon. It contains acid. If you mix it about five to one with water and a spray bottle you have a vicious cleaner that will do most any deed you want it to, including eat the skin off your hands. Read up on it. It's scary but can get some things other cleaners wont. Not meant for oil and grease but it can be used for stains in aluminum castings. You need big water to flush as you clean. |
+1 gunk...cheap and really effective |
ZEP Alum - Left Side Photo Gallery by 914-6 GT at pbase.com |
I feel like I have used most the recommendations here. Pressure washing is a great first effort, and yes be careful with that. I find that Oil Eater works really well and is not so harsh. Also mineral spirits is great on the oil and fantastic kn cosmoline. I find Purple Power relatively harsh. Simple Green is OK. Both of those are risky on aluminum and need to be rinsed very well.
On bare metal, scotchbrite pads with the cleaners are very helpful, but very harsh on painted parts. I bought a whole kit of plastic tools used for auto trim removal, any there are two or three in there that are incredibly useful for scraping thick oil sludge and cosmoline off. It's a crusade... |
| All times are GMT -8. The time now is 03:19 PM. |
