‘87 High Beam issue
When I turn on the high beams my headlights turn off. Where should I start to diagnose this issue?
RETIRED
Turn signal stalk.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
high beams are separately fused from low beams -- start by checking their fuse (and swapping with low beam just to be sure). Do high beams work if you pull the stalk to flash them?
AFter a few turn signal stalk changes and trying to extend the life of the stalk by spreading the metal contacts, I purchased and had installed The Classic Retrofit fuse holders (front and back) that incorporate a relay for the headlights/turn signals which takes the load off the turn signal stalk.
https://www.classicretrofit.com/en-us/collections/blade-fuse-panels/products/911-front-fuse-panel-1974-1989
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
They do not flash if I pull the stalk. They completely turn off when I push forwards on the stalk to engage high beams.
I had previously upgraded my alternator to the Classic Retrofit 175A alternator due to voltage drops with all the electrical load with four condenser fans and hurricane air conditioner blower fan from Griffith's. I was so impressed with it that I decided to replace the fuse blocks, front and rear, with the CR kit to keep modernizing the car for long life in a stealthy manner. I retained the original fuse blocks.
That Pelican Parts / JWEST Engineering headlight relay kit is a great upgrade at a great price.
The only thing I don't like in the instructions is tapping off power by adding another wire to the battery terminal and would instead prefer it to be connected onto a different high current location. My choice for this upgrade was instead to use those round Porsche relays, populated into the two empty relay locations, for an OEM appearance, unfortunately at a much higher cost. |
The relay did not fix my issue.
Welcome to the forum.
The Bentley Publications wiring diagram for your 1987 911 has been studied and it doesn't make any sense. The OEM Porsche Factory Service Manual set was ordered over a month ago and is expected in several weeks. It sounds like it is coming from Germany. When it arrives I will again examine the headlight schematic to see if better information may be provided. Use low beams until then...
1986 911 Carrera Targa 2022 Macan |
