-   -   Need help finding CIS part for 81 (http://forums.pelicanparts.com/porsche-911-technical-forum/937274-need-help-finding-cis-part-81-a.html)
Kemo 11-28-2016 01:53 PM
on my 81 SC, I have a small crack in the black rubber hose at the AAV (the red thingy in the picture). What I need is the rubber hose in this pic. Anyone know where I could source a new one? if they are NLA, can I fab one up? I was not able to find one in the catalog.
http://forums.pelicanparts.com/uploa...1480369985.jpg
81SC 11-28-2016 02:29 PM
Is this the one you're looking for?
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
boyt911sc 11-28-2016 03:43 PM
Vacuum hose.......
Steve,
The red thingy in the picture is the AAR (auxiliary air regulator) and the round saucer like thingy is the AAV (auxiliary air valve). These two components are commonly mistaken for one another because on the language translation from German to English in the early years. Anyway, if you need the vacuum hose for '80-'83 SC, you would need the three-legged vacuum hose. The diagram shows the early CIS set up.
PM me if you still need a good used three legged vacuum hose for your engine. BTW, I never got a reply if you have recieved the WUR-045 I sent you. Thanks.
Tony
Kemo 01-06-2017 07:43 AM
so here is the hose that I need..i accidentally bought a 3 way hose
http://forums.pelicanparts.com/uploa...1483717381.jpg
and here is a comparison...I need the one with 3 legs and a 4th to the CIS boot
http://forums.pelicanparts.com/uploa...1483717420.jpg
targa44 01-06-2017 11:40 AM
Tony - is the auxiliary air regulator (AAR) sometimes referred to as Fast Idle valve?
thanks,
boyt911sc 01-06-2017 12:44 PM
Aar?..........
thanks,
KJ,
Well, this is the first time I heard the AAR referred as Fast Idle Valve. The AAR causes high cold idle because the metered air is by-passed directly above the throttle body. And the slide valve inside the AAR gradually closes as the heater heats up the bimetallic spring till fully closed. FIV (fast idle valve) is probably a good synonym for AAR.
Tony
boyt911sc 01-06-2017 01:08 PM
Three-legged vacuum hoses.......
Steve,
Found some AAR vacuum hoses for you. PM sent.
http://forums.pelicanparts.com/uploa...1483736836.jpg
Tony
