Crazy Wobble... Looking for Advice
Hello,
I've been chasing a weird wobble for several years. Below are the clues: 1. Car drives like it's on glass up to 80 MPH. 2. Above 80, there's a wobble that can be felt through the steering wheel and the seat. 3. It comes and goes. 3a. It can come and go based on long sweeping turns. 3b. It can come and go on its own (straights). 4. It doesn't matter whether the clutch pedal is depressed. 5. I've had the tires changed; no difference. I've had the wheels balanced a number of times. Each time, the problem goes way down, only to come back in slowly and grow through time. I'm talking to Cheech up at Rennwerke. He's convinced it's not an axle or the differential, which were ideas I had (given that I've balanced the wheels so many times). He's also pretty sure the wheels are true, and that his guys balanced them well the last time I was in. So what I have is an intermittent wobble, that doesn't seem to have any apparent source, and that isn't solved by wheel balancing. Any thoughts would be welcome.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Check your wheel bearings and your ball joints.
Just my .02 cents. Good luck.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Give Cheech the car and let him fix it. It will cost a few $$$$$ but it will be fixed.
Wheel bearings have been checked, but I'll ask him to check them again.
Cheech had it last time, and they did the last wheel balance. He's scratching his head a bit (as I am), at what this could be.
Redo your alignment to have more toe in... that will mask a lot of vibrations...
Then check your tie rods/steering column u joints, etc... Does the steering wheel wobble? Or does the car just shake? |
don't you have any spare wheels ? find a buddy with some wheels that will fit and put them on . you need to eliminate the wheels not the tires. I have three sets of wheels for my car for example coz im too lazy to sell them , im sure there might be a pelican in your area with a set of wheels lying around for troubleshooting.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
You want to have your wheels balanced on a Hunter Road Force tire balancer, It balances the wheel with a rolling resistance.
Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can't fix |
I'm going to guess it's mechanical.... somewhere in the links. You've tried several things along the way. Here's 2 things (not knowing if you've isolated front or rear) that have happened to me:
Front - Boge struts with Bilstein inserts... the wedge pin that secures the bottom of the insert to the strut can back out or be loose and might? set up a vertical vibraton - but it seems it would happen at any speed. Rear - Didn't have the large cotter pin securing the axle nut installed and a rear wheel was trying to come off. good luck, |
I had a slight shimmy over 80mph. New tires, perfect wheels, etc. Then my steering column bushing failed and after I replaced it, no shimmy regardless of speed.
Does your steering wheel have any play left and right or up and down? |
Steering wheel and rest of car. Quote:
I replaced the steering wheel bushing a few years ago when it disintegrated. I think I used the Leland Pate bearing that he developed on Pelican?
Did Cheech give you Hunter printouts that verified all 4 wheels are true?
The report would state the rim runout to the 1/1000th of an inch, and determine a binary pass/fail on the wheel. Apparently, you can balance a bent wheel, but it may be a band aid that causes uneven tire wear. Alternatively, you can call this guy in Yonkers. The Wheel Doctor NY Wheel Repair and Vibration Specialist | Wheel Repair and Vibration in NY He is a wheel freak, knows 911s, and he will definitively rule out your wheels, if true. If a wheel is bent, he will straighten, remount, and RoadForce balance it for $175.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 09-21-2016 at 04:09 PM.. |
I did not get printouts. I'll give this guy a call and see what he has to say.
Fleabit peanut monkey
Good input.
Daniel Dudley's rolling resistance is a keeper as well. I say rubber.
1981 911SC Targa |
Appreciate all the feedback. Heading into Wheel Dr. on Friday with the car and my original two front sixes. Heading into Rennwerke on Saturday, hopefully with that problem solved, for next steps.
Any resolution ?
1986 Bosch Icon Wipers coupe. |
Yes, I'm interested to hear about your experience at that Wheel Doctor shop.
Rennewerke has very mixed reviews here over the years but I have no personal elperience with them. If you still cannot get a resolution, I'd suggest a trip up to Dan Jacobs in CT. He posts here now and then and has done right by me for corner balance and alignments. Never heard of any drama with him, either.
Ken 1986 930 2016 R1200RS |
To put a nail in this one, and to pump a quality business, Wheel Dr. was able to give me more information and care than any of the top NYC area shops had over the last 3-4 years. One of my tires is basically a mess - it was throwing 36 lbs of pressure on the road force machine. Tony(?) spun it on the wheel a number of times before declaring it fit. How the other shops missed it is a mystery. This guy does top quality work, and was a genuine pleasure to spend an hour or two with. I can't recommend him highly enough. No one else will ever mount tires for me again.
So all you needed to do was replace one tire?
Yep. A few of the other tires were slightly off balance but it was one rear that was the main culprit. I didn't even replace it as I had to leave with the car that day. He spun it about five times in the rim to get it as good as possible. It's a thousand times better. Still noticeable but I'll replace when I can.
The mystery is why four other shops missed it... They were putting weights on it and calling it good. |
