Porsche Crest 1979 porsche 911sc with weber carbs
Hi every body, mi 1979 Porsche 911 SC 3.0 have Weber carbs instead of the fuel injection system.
does it need the fuel pressure accumulator? I removed it and it has a start problem.
can some one help!!!!
Happy Christmas
Old 12-22-2013, 07:51 AM
79 Euro's Avatar
I have a 79 SC too and would love to have your set up
Andy Kay
Kennedale, TX
817.948.8538
1979 911 SC Euro - Guards Red
Old 12-22-2013, 08:00 AM
VFR750's Avatar
A lot of questions. First you should not have an accumulator with carbs.
Did you buy this car with the carbs or did you install them? The reason l ask, is it helps if you know the history of the conversion.
Does it have the stock fuel pump? You should have a pressure regulator set at 3.5 psi, supplying fuel to the carbs. I can't imagine how it ran with an accumulator.
Can you describe the fuel setup, and take some close up pictures so others can see what you see?
Old 12-22-2013, 01:13 PM
VFR750's Avatar
Trying to look at your setup in the picture. It looks like it was done right.
Where was the accumulator you removed?
Old 12-22-2013, 01:18 PM
I don't know what a fuel pressure accumulator is, but you shouldn't have one for your carb set-up. You should have a fuel pump that supplies 1 to 4 PSI of fuel pressure and fills the bowls on the carbs.
Carbs are hard to start when cold. If the car has sat for a few days or more the fuel evaporates out of the carbs and you should run the fuel pump for 20 seconds or so before trying to start the car. You need to pump the gas pedal to squirt fuel into the cylinders before the engine will start when it's cold. Practice will show how much you need to pump to start the car. You can also pump the gas pedal while cranking. You might need to keep some gas pedal down from idle in order to keep the engine running for 20 seconds or so after starting.
-Andy
Old 12-22-2013, 01:23 PM
Eva
911SauCy's Avatar
First order of business immediately following resolution of this issue...
Do yourself and engine a loving favor...ditch the garbage FRAM filter.
Happy motoring
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 12-22-2013, 02:10 PM
Porsche Crest
Thank everyone
Old 12-22-2013, 06:20 PM
...and my blue mistress
mazing3's Avatar
OK I'm stumped. Built my own 3.2ss with PMOs but can't for the life of me figure out what that red box with the 6 black hoses coming out of it does. the one by his pressure reg, not the Dizzy
Robbie
1976 Carrera3.0
1978 928 5spd
Old 12-22-2013, 09:13 PM
rsscotty's Avatar
That would be a vacuum reservoir for a power brake car.
Old 12-22-2013, 09:30 PM
vaccume box
Yes , is the vaccume register of all 6 manifolds for the power brakes
It works realy well ....
happy Christmas to all
Old 12-23-2013, 01:41 PM
Who makes that manifold and was tapping the carb manifold difficult?
1982 911 Targa, 3.0L ROW with Webers
Old 12-23-2013, 01:46 PM
rsscotty's Avatar
Vacuum manifold
This is a link to a vacuum manifold I found in the past...there are various ones out there, but this looks similar to the one in the picture above.
Vacuum Manifold Kits
Old 12-23-2013, 02:49 PM
tapping the manifolt
it was easy
Old 12-31-2013, 04:15 PM
