-   -   DP Motorsports project sleeper 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/937396-dp-motorsports-project-sleeper-3-2-a.html)
Elombard 11-29-2016 12:52 PM
DP Motorsport Project Porsche 911 Sleeper Pictures, Pricing and Specs
I dont remember seeing this car? I remember a white one.
Anybody have any more details - how did they get the weight below 2000 lbs?
DRACO A5OG 11-29-2016 01:07 PM
Originally Posted by Elombard (Post 9376956)
[url=http://flatsixes.com/cars/tuned-porsches/the-dp-motorsport-project-911-sleeper-3-2/]Anybody have any more details - how did they get the weight below 2000 lbs?
Got rid of lot of stuff:
Side rockers and rubber
Engine Seal Rubber, struts ( Maybe more )
Back Seats
Probably replaced allot of panels with plastic, maybe bumpers and bumper struts, etc etc.
clutch-monkey 11-29-2016 01:19 PM
looks great, serious weight loss though.. no idea how they got it that low
Trakrat 11-29-2016 01:25 PM
based on the article....
carbon fiber panels
metal supports drilled to swiss cheese, leaving only minimal structural stiffness
titanium exhaust
minimal interior
AC and heat removed
plastic and rubber bits removed
plexiglass windows
and of course... a "thin coating" of paint...:rolleyes:
But seriously.. titanium exhaust and carbon fiber panels will save you a lot of weight... that's probably at least 200+lbs?
lightweight seats... and other interior bits... another 150lbs?
comfort parts removed (heat, AC) another 100lbs?
glass and all the rubber and plastic bits... another 100lbs.?
finally cutting and drilling out extra metal.
Depending on carbon fiber usage... if you replaced all panels, gas tank, roof, and other components with carbon fiber... that would be a lot of weight.
steenkamp 11-29-2016 02:05 PM
Have a look here:
Gewichtsreduzierung
Text is in german but there are a lot pics of the build
Guido
Mehoff 11-29-2016 03:13 PM
They didn't. My guess that car weighs around 2,300lbs if it started as an '86 (maybe slightly less completely dry, as there's about 90lbs of fluid in these cars at half a tank).
Spec 911's can barely get to under 2,200lbs and there is absolutely nothing left of those cars. This one still retains a semblance of a street car
75 911s 11-29-2016 04:52 PM
Shows the bumper blades are carbon fiber. That's pretty cool. Wouldn't mind having a set of those.
Flieger 11-29-2016 05:08 PM
Isn't that with ballast?
The DP car is pretty much the same weight as mine, give or take a couple gallons of fuel.
Elombard 11-29-2016 05:08 PM
Yeah if I remember right the following parts on the white car were CF - probably the same here:
Roof
Hood
engine cover
bumpers
front fenders
engine shroud and tin
Seats
more I cant remember
Elombard 11-29-2016 05:30 PM
Wow that link to the German DP site is cool. That dash board set up looks really nice.
Mehoff 11-29-2016 05:36 PM
2,200 is the lightest I've seen on a post-74 car. I believe prior to that the tubs were about 200lbs lighter?????
Ballast on the Spec 911's is usually for lighter drivers.
My direct comparison would be my Carrera Spec/Spec 911 race car. Still has metal fenders/hood and rear quarters, but other than that there is not even a superfluous bolt in the car; literally nothing left to be lighted/removed without cutting into the tub (doors weigh 30 lbs together). That car weighs just under 2,300 with fluids.
Flieger 11-29-2016 06:02 PM
I don't know, your cage is probably much more extensive than the DP car and the steel panels are still going to be quite heavy. My car could still loose a few more pounds.
Wout_RS 11-30-2016 10:34 AM
Anyone has video's of this car with titanium exhaust?
Expensive pricing on the site for the lightweight materials :o
steenkamp 11-30-2016 11:59 AM
https://www.youtube.com/watch?v=4UfjEhTXmxU
(pics only)
eolson 11-30-2016 06:59 PM
It's kind of killing the idea when you write "Sleeper" on the deck lid. Awesome car nonetheless!
Canada Kev 11-30-2016 07:32 PM
Nice car and likely very quick with all that weight removed. But they could have saved a few more grams by cutting off the airbox cover... ;)
And I don't know, but with the rockers removed on impact bumper cars, in a profile view, they look like they're sucking in their gut.
http://forums.pelicanparts.com/uploa...1480566727.jpg
3literpwr 12-01-2016 01:05 AM
First...Respect to people not doing backdates!
Would be more balanced with no front spoiler and a tad less rake. And yes, the "Sleeper" badge and boy racer fenders sticker don't seem in line with the cars title.
stownsen914 12-01-2016 04:10 AM
It does say in the article linked above that they got the car "a little less than 905 kg (about 2000 lbs)" ...
Tippy 12-01-2016 04:29 AM
The power-to-weight ratio is dead on with a C5 Z06 Corvette.
Those cars moved pretty decent.
ChrisBennet 12-01-2016 08:57 AM
The site said they were getting around 270HP with ported heads, different cam but stock air meter. Doesn't that seem suspiciously high?
HorstP 12-01-2016 09:20 AM
DP is a well known company with good reputation. They would have no reason to claim anything they can't hold. So far I have sourced only one CF part from them, the tunnel cover. Excellent quality. Wallet permitting, it is tempting to get all the CF parts for the rear from them. Only thing is, I live in a city, the smallest hit even at a parking lot will be very expensive...
Wout_RS 12-01-2016 10:38 AM
http://i65.tinypic.com/aoqtch.jpg
More balanced from the other side with the ducts running there.
Aren't they on both sides?
I had the idea to do this on my G-model. Is this the results from only removing the rockers?
will hung 12-01-2016 10:46 AM
The oil lines only run on the right side. And yes, this is the result of removing the side rockers.
QueWhy 12-22-2018 07:11 PM
Bumping an old thread and an awesome car.
Does anyone know the color of this car? I didn’t see it in the articles. Also is there a US distributor for these light weight parts? They make the only fiberglass repro of the factory valance I’ve seen. I’d be interested in a set of those mirrors too.
Ian Comerford 12-22-2018 10:54 PM
The mirrors may be these from Ruf. I have them on my car and they are asymmetric.. https://ruf-automobile.de/en/product/ruf-sportspiegel-kit-2/
Rob T. 12-23-2018 03:00 AM
Does anyone know the color of this car? I didn’t see it in the articles. Also is there a US distributor for these light weight parts? They make the only fiberglass retro of the factory valance I’ve seen. I’d be interested in a set of those mirrors too.
Hy Quewhy,
as far as i know, the colour is Felsengrün metallic (699).
You can also become the mirrors at dp motorsport. Here is a link:
https://www.dp-motorsport.de/31.html?L=1&detailid=1122&product=52
I had these mirrors too. Mounted them on the little side window with one component adhesive.
QueWhy 12-23-2018 05:38 AM
Originally Posted by Rob T. (Post 10293033)
Hy Quewhy,
Thank you. I had a feeling it was Felsengrün (what we call Granite Green) but it seemed lighter an with less green than other pictures of cars painted 699. Going back now and searching through images it seems that color is highly variable depending on lighting.
I found the parts catalogue here Porsche 911 G-Modell Karosserieteile one could go crazy with all those weight saving bits. I was more curious if there was a distributor in the US that stocked dp products.
Ian,
Thank you for the link to the RUF mirrors, they look similar to the ones from dp but are quite a bit more expensive.
786 12-23-2018 07:29 AM
Yes, color is 699. I tried emailing them a couple times but no response. I’m in Leverkusen often for work, I think next time I’ll just drop by.
I like this build by them but personally my favorite build they’ve done is the Superlight RSR. 850kg and 292hp iirc. And that Ti exhaust drool
http://i.imgur.com/Kp32yKr.jpg
http://i.imgur.com/PzuPRou.jpg
http://i.imgur.com/rVo18Me.jpg
Ian Comerford 12-23-2018 08:03 AM
Ian,
Thank you for the link to the RUF mirrors, they look similar to the ones from dp but are quite a bit more expensive.[/QUOTE]
I see what you mean, nearly half price! Wonder where the difference is? Are the DP ones asymmetric? Very happy with mine though, plenty of visibility and adjustment, plus a noticeable decrease in wind noise over the flags. As a result the car is much faster......
Ian
QueWhy 12-23-2018 08:17 AM
I saw that one too but I really like the way the sleeper 3.2 retained the stock G-body appearance while shedding so much weight. Plus the color is stunning. Maybe I’ll call them after the new year and inquire about how to obtain their parts.
786 12-23-2018 09:13 AM
Ian
I believe DP was the originator of this type of mirror, same with their lollipop seats.
Canada Kev 12-23-2018 11:49 AM
And think that originally back in the day, if you bought a set of those mirrors, they threw in a 935 race car as well... ;)
786 12-23-2018 06:15 PM
Lol, yes sir
jjeffries 12-24-2018 11:20 AM
My fave DP was always their 944 shooting brake, aka 2 door wagon. John
