RETIRED
What is underneath the rear seat floor pan?
I have to put a couple of self tapping sheet metal screws into the seat pan. The seats have been removed and I won't extend more than 1/4 inch. Just above where the FX is sitting/laying. NOT into the tunnel.
Is there anything under there that I have to worry about? This to anchor an angle iron to secure the seat delete box. I would rather know what to look out for before I crawl underneath with a flashlight.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
Sorry, wrong pic loaded in the first post....and should be turn 90 to the left....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 11-30-2016 at 03:52 PM.. |
On an SC that might be close the hard fuel lines that run up from the tunnel to the filter though its really hard to tell from the pic.
1982 911 Targa, 3.0L ROW with Webers |
RETIRED
Above the tunnel, in the middle where the seats are. Do the fuel lines turn 90 up from the tunnel or go straight back from the hump? That hump is 4 inches above the tunnel....
The fuel lines are 45 deg to the tunnel, you have to be careful of the brake assist vacuum line that runs up and over the T tube in the driver's side rear seat back
crude rudy '84 cab '14 ZX-14R |
RETIRED
See the penny? RIGHT there is where I wanna put the screw.....
Neerlandofiel
On the RS America, the rear seat delete is held in place by two small brackets bolting to the two outer rear seatbelt mounts.
1990 944S2 Baltic Blue 1,960 original miles 1989 944S2 Guards Red 82,000 miles Gone: 06 Exige, 08 Cayman S Sport, 67 911R Hotrod, 09 Cab, 93 RSA, 91 964, 13 Boxster, 15 Macan S, 05 Elise, 00 M-Coupe, 71 914-6, 75 Carrera, 11 997 GTS etc.. |
RETIRED
I am already using those anchors. I need another one on the bottom front. But thanks....
