Anyone with 1978-79 SC ??????
I need some help with vacuum hose locations from anyone with a 1978-79 SC. There are two vacuum hoses from the WUR.One comes out the side and goes to the thermo valve. The other comes off the top and would guess goes to the throttle body. I need help with the location of where the hose from the top of the WUR goes to. A picture of the location or a diagram would be appreciated. thanks for any help. Joe W
Joe W 75 911 Wide Body 87 944
Old 01-12-2003, 05:26 AM
It'll be legen-waitforit
stealthn's Avatar
I have a 79, but I have no idea where the WUR is. You point it out to me and I'll trace the vacuum lines....
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 01-12-2003, 07:30 AM
Pelican has some excellent paers diagrams
http://www.pelicanparts.com/911/911_Parts/1978-83/1-7-2.JPG
Old 01-12-2003, 07:37 AM
Sean Hamilton's Avatar
Remove the rubber air duct and you'll be able to trace THAT vacuume line.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 01-12-2003, 07:48 AM
gblumenstock's Avatar
I have a 79SC (California) Here are some photos of the vacuum hose connection to the throttle body. Hope this helps.
GB
Old 01-12-2003, 08:00 AM
Original Owner
tsuter's Avatar
The hose from the top of the WUR goes to the throttle body ABOVE the butterfly. The nipple is on the on the upper side of the throttle body facing to the rear of the car. Make sure it is attached above the butterfly as that line is to outside air pressure i.e., not below the butterfly. The line leaving the WUR on the lower end is to a vacuum source via the thermo valve to the throttle body BELOW the butterfly.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 01-12-2003, 08:06 AM
Great!!!!!! thanks for all the help and the great picture. Tsuter you hit my question right on the head. I thought that top line was supposed to be a suction line too. I didnt feel any vacuum so I thought I had the hose hooked up wrong. many thanks to all who responded. Joe W
Old 01-12-2003, 08:12 AM
