-   -   SC/Carrera Owners: Picture needed (http://forums.pelicanparts.com/porsche-911-technical-forum/93781-sc-carrera-owners-picture-needed.html)
Axeman 01-10-2003 03:29 PM
I'm in the process of putting window regulators from an SC/Carrera on my 75 and I need some help. I have to drill a couple holes to mount the regulators, but I'm not too sure about the exact location. Does anyone have a close up picture (or 2) of your doors with the panel removed, so I can clearly see what I need to do?
Thanks much!
1980SC 01-11-2003 08:03 AM
Here are a few shots of my 1980 SC's door:
http://forums.pelicanparts.com/uploads/wlarge.JPG
The holes you need to drill :
http://forums.pelicanparts.com/uploads/wsmall.JPG
What you really need is a copy of the Technical Bulletin #7, "Installing Cross Arm Window Lifters". It has a diagram with the coordinates for the holes you need to drill. I tried to photo it, but my camera isn't that good. Perhaps someone else can.
Rob
1980SC
Axeman 01-11-2003 10:06 AM
Rob,
Thanks a lot for the pics, it will definitely help a lot. If someone has that technical bulletin #7 that would be great! If not where can I buy it?
Thanks,
1980SC 01-11-2003 10:24 AM
1 Attachment(s)
The Technical Bulletins are in the "Parts and Technical Reference Catalog" that I bought at my local Porsche Dealer for around $10 or $15. It's a very handy book. Lists all the part numbers for the car.
You are also supposed to update the lower window "channel" to the new style when you use the newer type window regulator. I need to replace mine, as it just broke. It can be seen here as the shiny piece :
Axeman 01-12-2003 01:31 AM
Thanks Rob! I'm going to try to get the Technical Bulleting #7 and use your picture, it shouldn't be too hard. If anyone else can send me the info from the Tech Bulletin that would be great too.
Thanks!
steve911 01-12-2003 07:15 AM
Axeman--
PM with your address and I can drop a copy of it in the mail.
