Don't understand timing marks on pulley
1 Attachment(s)
The timing specs for the '72 are 5 ATDC at idle 32-38 BTDC at 6000 rpm. But the marks on the pulley don't seem to help with these settings. Looks like below - what does "FE" mean?
I don't know what the FE means. Are you having trouble timing your car?
Not right now - I'm fixing carbs. I'll need to determine 5 ATDC when I set the timing. My light has advance - not sure how to go the other way.
Greg, I brought this thread to Ron's attention...I hope he weighs in later. Just a little tip here tho...think backwards. When you are looking at the timing marks on a P car, think backwards from looking at them on a Detroit V-8...even though you are standing behind the rear of the car, you are looking at the front of the engine in a 911.
Greg:
The FE is the mark for timing your MFI pump; I won't go into any more details than that. It's used to insure your MFI pump is timed correctly with the rest of the engine. If you need to get the MFI pump synched with your timing, be sure to read the instructions very carefully or you can easily be 180 degrees out of whack. I know because I'm been there before and the engine doesn't run too well (or at all). The Z1 I believe is top dead center, with the 30 and 35 being the BTDC (before top dead center) timing marks. Hope this helps. |
what does the 5 mean on my SC pulley
MJ |
MJ, I'd guess the it's the 5 BTDC timing mark.
Ron, I don't know what dizzy I have. My initial guess would be the stock MFI dizzy, but I'll figure it out today. Here's a theory. The pulley timing marks are consistent with the timing for a 70/71 engine, according to the Haynes manual. When the engine was built circa 1975 (replacing MFI w/ carbs) they removed the 72 pulley marked for the 5 ATDC / 32-38 BTDC specs with the earlier one marked for TDC / 30-35 BTDC. Why? Dunno. Maybe that's how they wanted it timed...? I guess my question is - how do I set timing? (a) 5 ATDC at idle, 32-38 BTDC at 6000 rpm per the 72 spec, requiring me to place my own 5 ATDC mark. (b) TDC at idle, 30-35 BTDC at 6000 rpm per the pulley. |
Yes, I have no timing today
All the carb leaks are fixed and all the adjustments are now effective. New plugs, valves adjusted, plug wires now plugged into the correct plugs (i.e. how to make your 911 backfire :eek:).
But, the timing is erratic. Idling around 900-1000 the best I can get is TDC stable for a few revs then advances and falls back. As rpms increase, it becomes more erratic - I was expecting a smooth advance, yes? My dizzy is a BOSCH 0-236-169-005. I have a Crane XR700 optical unit and an MSD 6AL. Where to begin ... ? |
Re: Yes, I have no timing today
| All times are GMT -8. The time now is 05:42 AM. |
