8 or 9
Can you tell by the pic if these are 8 or 9" Fuchs?
http://forums.pelicanparts.com/uploa...1480886957.JPG |
I would think 8. My sidewalls looked a little more stretched when I had 9s on 245/45/r16 tires.
Looks like an 8, 9s have a recessed lug area if I recall, can't tell from the angle. Pull the wheel and look inside for the specs.
I think 8s, the nuts look at surface, not recessed.
Bruce |
Yeah, they look like 8 to me too. Which makes sense as 8" were the standard rear size for Fuchs in '88.
Most definitely 8s, not 9s.
Although 8s were NOT standard for the rear for 1988. |
That's true.
I've got 8's on mine and they look identical to that, down to the tyre sidewall bulge. Anyone have a picture of their car with 9's?
Here are close ups of my 9's
http://i66.tinypic.com/15gys83.jpg http://i68.tinypic.com/rbffp5.jpg http://i65.tinypic.com/a0cmz5.jpg |
I don't think 8s were standard. I have an '88 Carrera Cab that came with 7s and 6s.
Take them off and look at the size?
-Steve |
Looks like the lugs are more recessed on the 9s based on close up of sugarwood
The wheels pictured on the white car are 16x8. Plus they have old Bridgestone S-03 tires (stopped production around 2007 I believe) so take that for whatever it's worth- old tires due for replacement based on age alone.
my 9's. Hard to tell as I thing the 8's and 9's have the same size dish.
http://forums.pelicanparts.com/uploa...1480973553.jpg |
the 9 is 1" wider overall, .4" on the outside and .6" on the inside. |
| All times are GMT -8. The time now is 11:05 AM. |
