Spitting fuel from exhaust
I had my sunroof seal replaced and I suspect the mechanic who did it either turned the ignition key on and off 200 times or just left the ignition on the whole time working on the car. More likely he turned it on and off many, many times causing the cold start valve to flood the engine. Because the engine was hydralocked with flooded fuel and so the starter would only give me a 1/10th of revolution each of the few times I gave it a try over 5 minutes. But after 10 minutes of waiting it actually did crank the starter continuously at a normal speed and the engine took at least 30 seconds of cranking (it's never taken that long before) before it started to hit and finally started. Then it was spitting unburned wet fuel from the exhaust while idling. Is that normal for a flood engine in idling recovery from flooded state?
The engine's now been run for a cumulative 1 hour of running over the last 24 hours and I'm still getting some spitting of fuel liquid out of the exhaust. Is it surprising that it's taking this long to clear up or could there have been some permanent damage done?
Is this series of events surprising from a technical point of view?
And then it was idling too high after it warmed up, and it's never done that before. Maybe I lost a vacuum line in the process? Maybe airbox leaking now coincidentally?
Last edited by octanemaestro; 12-05-2016 at 07:20 AM.. Reason: send notifications forgot, oh, too bad can't change that
Old 12-05-2016, 06:44 AM
Registered Minimalist
75 911s's Avatar
What year? Sounds like an earlier car that has the fuel pump come on when you turn the key to acc1. Try an Italian tune up?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-05-2016, 07:20 AM
theiceman's Avatar
well regardless id be changing that oil ... I bet tons of fuel has leaked by into case.
I am not 100% but I thought CSV only fired during " start" not on ignition on.
May depend on year though .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-05-2016, 07:28 AM
1981 SC Euro
What's an Italian tune up?
Old 12-05-2016, 07:58 AM
Vinyl pimp
Joe Bob's Avatar
Italian Tune Up=Drive the piss outta it....
Old 12-05-2016, 08:05 AM
Administrator
Jack Olsen's Avatar
Are you sure it's fuel?
Old 12-05-2016, 09:42 AM
T77911S's Avatar
if the FP runs with the key on that is what happened,
CSV should only run when in the start position.
you could be running a tad on the rich side.
could be condensation coming out of the exhaust.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 12-05-2016, 10:04 AM
A real cautionary note there.... On a VW, if the fuel pump goes bad and gas dilutes the oil, you're at danger of burning up your bearings. I suppose it's the same on a Porsche if the engine is hydrolocked. Smell the oil for gas contamination & take note of any increased volume...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-05-2016, 11:01 AM
DanielDudley's Avatar
Yep. Oil dilution can really screw up an engine. Stop running it and change the oil.
Old 12-05-2016, 12:55 PM
Tags
air fuel ratio , flooded , fuel , spitting
