| mysocal911 |
12-07-2016 07:03 PM |
Originally Posted by handleyb
(Post 9387791)
Dave,
Yes if I connect Pin 30 to Pin 87 ( no ground to 85b) the car runs.
I connected pin 30 to Pin 86 without any results. Brian
1. Time for a good DME relay.
2. Jumper pin 86 to 87 but only turn the key on without cranking the engine.
Then place your hand on the idle valve to see if it's vibrating.
It the valve is vibrating, you have power from the ignition switch thru the alarm
ECU to the relay and your problem is just a bad relay.
3. Remove the jumper before any cranking of the engine.
