-   -   Need Help - CIS Question (http://forums.pelicanparts.com/porsche-911-technical-forum/938240-need-help-cis-question.html)
red83sc 12-06-2016 01:54 PM
Hi All,
I've got a 83 911 SC. I was wondering
if anyone has replaced the "air valve" on this model. This specific "air valve" is not
to be confused with the "auxiliary air regulator" sometimes confused
as the "aux. air valve". I've replaced that one already. This one is a big disc with two connections on the back side. I've bought one and been able been able to find
it but have no clue how to get to it :confused:. It appears to sit behind the air box /
fuel distributor. My question is, how do you get to it ? am i missing something that dosen't requiring taking the air box / fuel distributor off. I enjoy working on the car but I don't want to get tooooo far over my head.
Thanks for the help,
rwest 12-06-2016 02:04 PM
Here's a link to doing a partial engine drop which might help replacing the part, you'll gain 4-6" of space. Not sure if that will do the trick, I replaced my whole CIS in one piece, so never just installed that part by itself.
Porsche 911 Partial Engine Drop | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
gazzerr 12-08-2016 05:32 PM
It's held onto a mounting bracket behind the airbox with 2 bolts. If you feel for the top hose on the gold donut then feel back towards you will find the mounting bracket. There's 2 mounting bolts. I *think* these are self tappers with a washer. You might be able to remove it but it might be difficult. Be super careful you don't drop the washers :). Partial drop it would be pretty easy. At a minimum you'll have to remove the rubber cis hat.
