Fuel Pump - for Euro 3.0
... suspecting "intermittent" issue with old fuel pump (how old???) and looking on internet for replacement.
Prices are all over the board - depending on pump. The car is a '73 with a 3.0 and pump in the rear - with no relay in line.... just heavier gauge wire I suspect.
I think I need the 911-608-102-00 (Bosch) based on "CIS" requirement - listed as for an SC.
My question:
Are the mounting requirements similar for "front" vs. "rear" ? The pump above lists it as front mount. Will I encounter problems or need to modify anything to fit to the rear?
Thanks,
Old 12-06-2016, 11:56 AM
I've used a turbo rear pump before with success on CIS installs in the rear.
Bruce
Old 12-06-2016, 12:11 PM
Hi Bruce,
.....Yes, that's on the list as well and that seems to be the most expensive pump by far.... it will be what it will be, but I'm hoping I can make something adapt to a rear mounting that also fits the spec required for CIS. I haven't looked at the actual rear mounting in many years and thought it was just strapped down - time to jack it up and get reacquainted.
thank you
Old 12-06-2016, 03:36 PM
