Weird Electric Spike w/turn Signal Op + Shift Issue
My early car does not get driven much, and recently I found the #1 fuse for the turn sig & brake lights popped.
When I operate the signals now the instrument needles jump & momentarily the gen light flashes on. It looks like the opposite indicator arrow flashes as well. It settles down immediately and the signals & brake lights operate. Also, suddenly is clipping reverse on the 1>2 shift. Assume that would be the lock out springs in the shift mech? Thanks for any thoughts |
Still no replies, thought I would give it 1 more shot
Thanks |
It may be the flasher relay is failing and overloading the circuit, or there is an intermittent ground on one of the signal housings. The usual suspects: Wire condition, connectors, grounds. Not much else on the early cars.
Tranny is for someone else to provide some ideas. |
Replaced the flasher, problem remains.
Checked all the grounds in the signal housings (and several others), they seem fine. Obviously something grounding/shorting as it will blow the fuse eventually. Head & tail. running lights operate normally |
The shift issue was the round bushing in the shift tunnel, failed into pieces. New rebuild kit from our host and all is well.
The electrical issue is solved, but I really don't know what I did to fix it. Replaced flasher w a generic FLAPS unit that actually made the problem worse (fuse blew quicker) but after a bunch of messing around with grounds and tidying up some old wiring bodges, and putting he original flasher back in, suddenly all is well. |
Once you clean off the corrosion by removing and replacing the flasher and clean the grounds up for better contact, those problems generally go away.
| All times are GMT -8. The time now is 03:40 PM. |
