you see Arthur...
Fuel Accumulator removal 82 911 SC
Just wondering if there isa trick to this. Been having a hot start issue, so ordered a new accumulator. I now its not the check valve, because I have a brand new fuel pump. All that said, just checking if there is a trick to getting this out of the car. Any insight would be appreciated.
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
This might help
![]() Porsche 911 Fuel Filter and Accumulator Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Registered Minimalist
What pump is it? The check valve is a separate attachment on some. The accumulator removal should be straight forward. It's held in by a hose clamp and the attachments to the fuel line and filter. Use a flared wrench if possible to prevent damage to the fuel line nuts. When putting it in, you must loosen the filter a bit so that the hard line between the filter and accumulator can sit on both fittings square before you tighten them up. Ensure that you have a check valve before putting that expensive part on that you may not need.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 12-07-2016 at 07:03 AM.. |
Your 82 accumulator can be checked to see if it is faulty as well. Remove the hose from the bottom of the accumulator and plug it (a little fuel will flow from the accumulator, that is normal.) With the hose plugged and a container or another hose connected to the bottom of the accumulator ending in a container, start the fuel pump. If fuel flows from the bottom of the accumulator, it is bad and needs replacement. If no fuel comes from the accumulator, your hot start problem is from some other source.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
you see Arthur...
seems easy enough to replace, can't get my flare nut wrench on the bottom, but further its really tight, is that normal? Should I try a little penetrating lube to help with the loosening?
Use 2 stubby wrenches, one on the nut of line and one on the nut on accumulator placed so that they oppose each other like a "V" and pull them together.
Just did mine recently (filter & accumulator) and 2 wrenches + penetrating oil did the trick. Also, found this advice in previously linked 101 tech article helpful "If necessary, disconnect the line from the top of the filter, and the bottom of the accumulator, and remove the two as an assembly. This will allow you to take the two over to your workbench to disconnect the hard metal line that joins them together."
And - likely goes without saying though none of this stuff ever does for me - keep in mind proper direction for loosening top and bottom. |
Fb = M/S
Please post if this solved your hot start problem.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
you see Arthur...
I will keep you posted. I have to get the old one out first. I suspect this is the culprit
14-mm and 17-mm open or flare wrenches.....
Follow the above suggestion using either open or flare wrenches. Do not forget there is clamp holding the fuel accumulator on the bracket. Tony Last edited by boyt911sc; 12-07-2016 at 06:22 PM.. |
Yep the V method with the 2 flare nut wrenches squeezed together is what worked for me.
I had what I thought were accumulator problems. I was told by a Tech guy to use non-ethanol gas. It seems to have done the trick. The alcohol was causing vapor lock in hotter weather. Cost more but well worth it
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
you see Arthur...
No Ethanol gas would be great. When my car was in Vancouver, Chevron had 94 octane with no ethanol. However, here in So Cal i can't seem to find a non ethanol alternative.. All that said, the accumulator is old, so it certainly cannot hurt to replace it.
It is premium and 360 a gallon, but worth it . The car runs great
