What are people using for timing lights?
Adding to my necessary tools for my car - was curious what people were using for timing lights?
Getting some backfiring at low RPM's so want to check.
Old 08-31-2017, 01:37 PM
Check your points
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-31-2017, 02:21 PM
Originally Posted by RSTarga View Post
Check your points
Check the gap with dwell you mean?
Old 08-31-2017, 02:31 PM
Jonny H's Avatar
I do a lot of ignition timing work and use an Equus 5568. Good mid price timing light. Soft rubber case. Has a bendy middle which sits nicely on the 911 rear slam panel.
Careful using the 'advance' feature. This uses the measured RPM to hold off the strobe. The light can be a little slow to respond which gives you misleading readings if the engine is changing speed quickly. I never use the feature.
I have managed to burn the strobe out on one though. Like I said, I do a lot of timing work!!!
www.classicretrofit.com
Old 08-31-2017, 02:36 PM
yes, backfires at low rpm's are sometimes caused by the wear on the fibre bar of the points. They close up. Put some new ones in and check the dwell, then set timing. Last timing light I bought was at Sears.
1991 C2 Turbo
Old 08-31-2017, 02:37 PM
Got it - new to all this. Reading some old threads - looks like the 78-83 didn't have points? is that correcT? I have a 3.0 out of an 83
Old 08-31-2017, 02:44 PM
I have this one from Sears, it has RPM too which is very handy when setting idle.
Sears.com
Rutager West
Old 08-31-2017, 02:50 PM
Jonny H's Avatar
More likely an air leak in the CIS causing the backfire. Take the air filter off and you'll see five slot head screws. If even a single one of those screws turns and will not tighten, then your air box is blown.
Old 08-31-2017, 03:09 PM
Thanks Jonny - in my reading I also have found this is common.
Old 08-31-2017, 03:37 PM
Just ran out 2 of those bolts were not tightening - guessing these airboxes aren't cheap? throwing a WTB up now since I want to get all the old parts fixed on this thing
Old 08-31-2017, 03:48 PM
Jonny H's Avatar
Don't succumb to the pop off valve BS. Most folks who have minor backfire issues (like you had) just don't know that their air box has failed already.
When fitted, the cracked box now blows open the pop off valve and they rejoice, thinking it has 'saved' them. It hasn't, their box is still cracked.
Further more, you can't reliably glue ABS with epoxy, so installing a valve can cause further back fires when this joint fails. In this case, this wonderful device 'saves' the airbox from an event that it actually caused. Brilliant!
So what causes the airbox to crack in the first place? Most likely heat, vibration and age. Yes it can be down to a lean mixture or timing issues. There is documented issue with fuel pooling in the bottom chamber which was resolved on later cars.
If you buy the current Porsche air box, it has the mods that stop the fuel pooling issue. Probably about $300 over there.
Old 08-31-2017, 04:35 PM
Great info thank you
Old 08-31-2017, 04:56 PM
I'll tag on what Jonny posted and agree that the pop off valve isn't something I put in on my new air box for exactly the reasons he stated.
I also wouldn't buy a used box since I also agree that with age the box gets brittle and is more likely to crack from a minor backfire. The spider inside should really help stop backfires as well.
Lots of threads on testing for vacuum leaks, do a search to find them- adding 5lbs of air into the port that feeds the brake booster and then spraying soapy water at every joint and look for bubbles.
Rutager West
Old 08-31-2017, 05:11 PM
Love this place thanks - will pressurize the system
Old 08-31-2017, 05:19 PM
Check this thread out.
HELP! have to let the car warmup???
Rutager West
Old 08-31-2017, 05:32 PM
Here's a great one as well.
CIS Troubleshooting for Dummies
Rutager West
Old 08-31-2017, 05:35 PM
Thanks was going through both of them - track tomorrow will get to this stuff on Sat. thanks all
Old 08-31-2017, 06:01 PM
