catspaw's Avatar
Yearly Preventative Maintenance
I've had my stock '74 2.7 for a few years and have been lucky enough not to have any issues. Here's my question, what yearly maintenance should be preformed aside from oil change. Presently I only drive it about 1500 miles per year.
Tundra
In Heaven the police are Brits, the cars German, the chefs French and the women Italian.In Hell the police are German, the cars French, the chefs Brits and the women Italian
Old 12-15-2016, 07:43 AM
Dave Colangelo's Avatar
It depends on miles and how hard you drive your car. I put about 10K (or more) on my car every year and generally speaking I like to swap,
- Air filter
- Oil filter (every other oil change)
- Spark plugs
- Distro cap and rotor
- Fan Belt (dont forget the shims!)
If its been a while and i want to turn some wrenches
- Fuel Filter
- Break pads
- Check the CV Joints
- Check the rotors
- Check all rubber bits
- Headlights when they die
- Other odds and ends bulbs when they die
- Tires if I need them
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 12-15-2016, 08:21 AM
Administrator
Luccia at Pelican Parts's Avatar
This is a good thread and looking forward to reviewing all the answers. OP, if you want to turn this into a list this might be a great itemized list that we can add to our tech article library for others that may be curious about how to take care of their maintenance on their P car that may sit more than it's driven. Let me know if this interests you (would get 10% off your next order with us if you decide to go this route). Info on that is here, but we may have to do yours a little bit differently: Enthusiast Tech Article Submissions - Pelican Parts.
Anyways, for my input, for something that sits mostly I probably would still do a yearly detail with a paint sealant for added/extra protection. Do you have a car cover for it? Assuming it's stored in the garage? Be sure to inspect your tires closely as I'm sure the tires on your P car might hit an age limit before wearing down. Listed below some items that I utilize. I'm sure more Pelicans will chime in as well.
Sealant Liquid Paint Sealant - 16oz - PelicanParts.com
GarageGuard Indoor Car Covers - Pelican Parts
Old 12-15-2016, 08:22 AM
faverymi's Avatar
Prevent rust.
Start changing ALL your rubber seals.
Your car will thank you
Old 12-15-2016, 08:43 AM
catspaw's Avatar
If you're asking me, sure. I'm actually compiling a list of items for itemsI want to address this winter. My Christmas present, a lift in the garage, may be in before the 25th. This is what I have on my to do list. Change brake fluid, change trans fluid, shift bushings, maybe a wevo, tidy up some rust in front of battery, remove ac components, and maybe move battery to smugglers box.
Tundra
Old 12-15-2016, 11:38 AM
