-   -   '71 911T rear end noise (http://forums.pelicanparts.com/porsche-911-technical-forum/939652-71-911t-rear-end-noise.html)
911buff 12-18-2016 10:49 AM
I think I know what the noise is but looking for a second opinion. Took my '71 out yesterday for a Cars and Coffee after not driving it for a while but quickly heard a "growl" coming from the rear. As I would would swerve (gently) to the right it would go away. As the car straightened out or went left, the sound was constant. I am guessing it is the right rear wheel bearing but again, looking for a second opinion. Thanks!
Porboynz 12-18-2016 09:55 PM
Lug nuts all tight? Wheel spins freely when jacked up? (well relatively freely with driveshaft etc to spin)
911buff 12-19-2016 06:36 AM
Porboynz,
Yes, all lug nuts are tight and the axle nut is tight (both sides). Both sides spin freely, relatively speaking. But the right side wheel seems to have a slight "growl" even when spinning it by hand.
I am going to jack it back up and conduct a stethoscope test to see if I can hear a difference between the two sides. Think I will also do a little diagnostics on the front wheels. It really sounds like it is coming from the rear but I could be wrong.
Thanks for the reply.
Fast Freddy 944 12-19-2016 06:58 AM
I get some mighty fierce rear end noises after a triple bean burrito meal from taco bell! I had the same issues with my 951, fortunately for me it was the cv half shafts. I reckon its your wheel bearings, you would be wise to replace all bearings on all 4 corners. Fast Freddy!
http://forums.pelicanparts.com/uploa...1482163125.jpg
:D
Porboynz 12-19-2016 09:36 PM
Originally Posted by 911buff (Post 9401835)
Porboynz,
Next step is to drop the CV and remove the brake drum/disc, you will be able to hear the noisy bearing easier that way. Of course that makes it more difficult to undo that big axle nut......
DRACO A5OG 12-19-2016 10:00 PM
Before that, make sure the cv bolts are tight, mine growled after I worked on the car and bolts came loose.
911buff 01-06-2017 08:23 PM
Finally had a chance to troubleshoot the noise. Turns out it was the inner CV joint bolts on the passenger side. Good call DRACO. Thank you for the tip.
